andylancaster3000
| posted on 31/5/05 at 11:06 PM |
Unlocking mobile phones
I have just bought a second hand phone which is locked to T-mobile (without the simcard) I would like to keep my current 02 sim so as not to have to
change all of the numbers across. How much will it cost to have it unlocked from T-mobile. Its a nokia, can't remember which!
I have noticed a couple of websites advertising between 3-5 quid to do it. Are these reliable or not?
Andy.
[Edited on 31/5/05 by andylancaster3000]
Davg
| posted on 31/5/05 at 11:19 PM |
Most nokia's easier to unlock than the others. General prices to unlock phones vary from £15 up try a seach for whatever the Nokia model you
have, should throw sumfink !
marshall
| posted on 1/6/05 at 06:08 AM |
i unlocked my samsung E700 from a seller on e-bay it cost me £2.00 and it worked ok and then i sold the phone on there. have a look good luck
mangogrooveworkshop
| posted on 1/6/05 at 08:13 AM |
Do a search under my user name and some where theres a website the lads gave with the unlocker from the imie code
mangogrooveworkshop
| posted on 1/6/05 at 08:31 AM |
http://www.locostbuilders.co.uk/viewthread.php?tid=19787
see this
andylancaster3000
| posted on 1/6/05 at 10:55 AM |
Mango: thanks for that link. I went onto the swedish site but have a little problem not knowing exactly which T-mobile network it is locked to, as
there are 4 apparently!
I may just bite the bullet and stump up the 15 quid to get it unlocked.
Mark18
| posted on 1/6/05 at 11:24 AM |
http://unlock.nokiafree.org/ and if that doesn't work, there's plenty more if you google it. Bear
in mind you only have 5 attempts before it has to be done with a cable at a dealers.
Mark
ChrisGamlin
| posted on 1/6/05 at 01:39 PM |
I can vouch that the above works, a colleague of mine used Unlock.nokiafree.org to unlock his Nokia 6100. Worked a treat and up and running in the
time it took to put in the PUK(?) number then type in the unlock code.
ChrisGamlin
| posted on 1/6/05 at 02:08 PM |
It also looks like if you
download the
Nokiafree application rather than use the online number generator, it will also unlock various other makes as well as Nokia
andylancaster3000
| posted on 1/6/05 at 06:02 PM |
I'm trying the nokiafree link above. When filling in the boxes I came to
'GEN:'
with the options : original, v1, v2, new griffin, etc..
What are these and which one is it most likely to be? (phone is a 3510i)
And also is it dct3 or 4? If it is dct3, which i have a hunch it isn't, what is the GID1?
Thanks a lot,
[Edited on 1/6/05 by andylancaster3000]
Mark18
| posted on 1/6/05 at 07:05 PM |
Good question - what I did was find a phone forum and found the answer there - can't remember for the life of me what it was though.
Mark
andylancaster3000
| posted on 1/6/05 at 07:13 PM |
Ok, thanks ill give it a go.
But you do have to wonder don't you...A phone forum...!
stephen_gusterson
| posted on 1/6/05 at 09:13 PM |
i got my moto v300 unlocked today. quotes on the net needed special cables or codes, and were between 16 and 35 quid.
took it to a little phone shop locally. they connected it to a little box, pressed a button, and 30 secs and 10 quid later, it was done
atb
steve
slingshot2000
| posted on 19/10/13 at 07:26 AM |
8 year old thread? Are you trying for some sort of record, you spammer?
