stephen_gusterson
| posted on 12/12/02 at 11:55 PM |
question for Scutter
Hi
I am pretty sure you are the aircraft tech?
I mentioned to my 14 year old son that a car ideally has a 'swirl pot' to hold fuel so that the car doesnt get fuel starvation when cornering.
Over the months, he keeps asking me to ask you how the heck does a fighter jet get its fuel - what with the G forces and attitudes the plane can
take.
Any ideas (not that Im gonna build a Tornado just yet
atb
steve
scutter
| posted on 13/12/02 at 06:21 PM |
The aircraft also have swirl pots just like car but they tend to hold around 50 gallons each and are backed up by air pressure that forces the fuel
into these swirl pots(collector tanks on an aircraft).
Hope this helps with the questioning
Take care Dan.
stephen_gusterson
| posted on 13/12/02 at 07:59 PM |
Thanks fror the answer!
So I suppose if you fly upside down too long, you might have a problem!
atb
scutter
| posted on 13/12/02 at 09:00 PM |
Yes the bombs never fall off the wings , also you get sick(well I do)
Take care Dan.
scutter
| posted on 14/12/02 at 09:51 PM |
proper job J/T propulsion tech, working at Boscombe Down.
Avatar pic of boss and co, Breaking things as normal.
take care Dan.
James
| posted on 16/12/02 at 06:39 PM |
take care Dan.
Would I be right in thinking that you can't sign up after 25?
Only reason I ask is that since last Farnborough airshow I've wanted to be a Eurofighter pilot ever since.
James
stephen_gusterson
| posted on 16/12/02 at 08:39 PM |
is 25 meaning years or pints?
atb
steve
geoff shep
| posted on 16/12/02 at 09:14 PM |
James, max at the moment for pilot is 23.
Steve, here's a bit of swirl pot action,
(thanks scutter, editted my previous post and deleted it)
[Edited on 16/12/02 by geoff shep]
scutter
| posted on 16/12/02 at 10:24 PM |
yeap that would make me sick
We've got one of the "ton" in the hanger at the moment.
All the best Dan.
stephen_gusterson
| posted on 16/12/02 at 11:00 PM |
Ah ha!
Now, that pic prompts a question I have always wondered about :
If the shape of an aircraft wing creates lift, why doesnt a plane lose lift when the wing is upside down - ie reversed profile?
Is it just a matter of somehow 'trimming' the wind leading / trailing edges to compensate? I could ask my C130 pilot realtion next time I see him,
but I doubt he flies hercs upside down that often
atb
chrisg
| posted on 16/12/02 at 11:06 PM |
Geoff,
Thats a nice hairyplane, what is it, and do they cost more in black, like cars?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
| posted on 17/12/02 at 08:48 AM |
quote: Originally posted by stephen_gusterson
Ah ha!
Steve,
The cross-section of most fast wings is nearly symmetrical - in fact, it doesn't have much cross-section at all on a fast jet!
When it's upside-down the plane has to fly with its nose pointing up more than usual (that's 'up' in relation to the ground, not the pilot's
'up' ), but there's still enough aerofoil to keep it flying.
It's not as efficient as right-side up, but it works on a fast plane. On a slow plane (e.g. a trainer glider) the aerofoil shape is thick and
flat-bottomed, and therefore hardly capable of inverted flight (it's usually forbidden).
(Guess who used to fly fast R/C slope-soaring gliders... but no longer... no slopes in East Anglia!)
jollygreengiant
| posted on 17/12/02 at 09:28 AM |
Chris
it a hawk trainer similar to those used by the Reds Arrows (if Im right the black colour is used by the training flight out in Wales, St Athan is it?
I forget the Sqn No)
Almost right.
Wings provide lift by virtue of speeding up the airflow over "the top" to create a relative drop in pressure compared to the underside which over
the entire wing creates lift. Generally the thicker the wing the higher the lift generated and a flat underside generates more lift relatively.
Military aerofoils Tend to be Laminar flow with similar profiles above & below the centre cord of the wing. Lift is Generated by increasing slightly
the angle of attack of the wing & by higher speed of the aircraft.
Inverted flight is maintained by pushing the nose of the aircraft upwards (stick away from you) so that you present the top of the wing (normally) to
the oncoming airflow and the limited turbullence this then creates past the leading edge & over the underside (normally) speeds up the airflow
creating lift to the underside of the wing. most aircraft will fly inverted quite comforably the limiting factor is usually the -G that the wing will
take which is why most helicopters cannot do a loop, beacuse there rotor will not take the -G stress's involved. Of Normal aircraft Aerobatics are
usually ok only limited by the spin characteristics which is a whole different ball game (& theres quite a few military jets Costing millions that you
just DON'T Spin cos they bite back)
Sorry but aerodynamics is quite long winded.
geoff shep
| posted on 17/12/02 at 09:37 AM |
Well, how long have you got?
Lets say the wing needs to be at, say, 2 degrees nose-up to produce enough lift to maintain level flight at cruise speed. It makes sense to bolt the
wing on at 2 degrees to the fuselage so that the fuselage flies level - to minimise drag etc.
Assuming the wing is as efficient upside down, then to fly level upside down the wing still needs to be at 2 degrees nose-up which is 4 degrees for
the fuselage. Actually, its not as efficient, as DJ says, so you might need 5 or 6 deg nose-up upside down.
So it's more to do with angle than shape, like the wings on the back of your F1 car. Vary the angle - vary the downforce. If they varied them all
the way to nose-up the car would lift off.
Chris, it's a Hawk. You can have any colour, so long as it's black - unless your a Red Arrow in which case it's red! All training aircraft are (or
are being) painted black because it makes them easier to see.
James
| posted on 17/12/02 at 09:48 AM |
Doh!
Oh well, that's that plan out the window- I'm 25 in April! Thought I had a few months to decide!
James
....Can you change your D.o.B by deed poll?
[Edited on 17/12/02 by James]
bob
| posted on 17/12/02 at 01:03 PM |
James
Plenty of time for you to go commercial,think of the benefits of overnights and hosties
[Edited on 17/12/02 by bob]
Simon
| posted on 17/12/02 at 05:21 PM |
Guys,
If any of you want to learn to fly - get into a weightshift microlight. VERY Cheap way to get in the air.
The RAF gents will no doubt tell you how good it is to fly at 500 mph at 300 feet.
I suggest you try 60mph at 7 feet - much more fun.
Even hedges and gates become a challenge, let alone the trees:-)
Don't get me wrong - love to have a go in something that climbs at 5 miles a minute.
Most fun ever had in a plane was a YAK52.
Simon
scutter
| posted on 17/12/02 at 06:10 PM |
Don't let the fast jet boys fool you into thinking that they don't go any lower than 300'.
Had a Tornado at west freugh in scotland nearly take my head off
But then he was doing a JP233 practice run(I'll let you all find out for yourselfs what a JP233 does).
Glad you lot answered the aerodymanics question, All I do is make sure that the engines work, if those aerofoils go upside down then something has
definatley gone wrong.
The hawk is a 100Sqn jet out of RAF Leeming.(up north)
ATB Dan.
[Edited on 17/12/02 by scutter]
| posted on 17/12/02 at 06:44 PM |
My most notable experience was in North Wales, while driving along a valley. It was a typical welsh valley road - just above the lowest part, to keep
out of the river.
As I was going along one of my kids said "look at that plane!" - looked horizontally through the hedge, to see an A10 passing us by at equal
altitude (about 25 metres above the river!). Shortly followed by his partner only just a little higher up (they went around in pairs).
They then zoomed up to a col and did that 'flip over and pull back' manouevre to get over the hill top without blacking out.
Impressive!
bob
| posted on 17/12/02 at 06:49 PM |
but there's no hosties on microlights
Simon
| posted on 18/12/02 at 12:14 PM |
Dan,
Wouldn't have something to do with runway denial, would it?
Simon
scutter
| posted on 18/12/02 at 01:09 PM |
Yeap, now banned because it used to spit out over 200 mines,
Bloody great thing, you could just about squeeze two under a tornado.
Take care Dan.
Simon
| posted on 18/12/02 at 05:19 PM |
Have to use a Daisycutter instead. I guess that would make one great big hole, rather than lots of little ones!!
Simon
scutter
| posted on 18/12/02 at 05:36 PM |
Now that's a great idea, a bomb that can only be dropped by a transporter .
Shame we don't have any, would be fun to try and strap it under a harrier.
Dan.
