New Topic New Reply
Author: Subject: chassis
heyzee
posted on 29/12/02 at 05:06 PM Reply With Quote
chassis
hi allthough im new to locost builders i have been messing about in my garage with loads of steel and a book on how to build a sports car.the trouble is the book seems to tell a few porkys.like tube [y]is it to small? and [z]the same?.could[r] be left out till the engine is fitted.i all so have a ford rear live axle about 52"WIDE FROM WHEEL FACE TO WHEEL FACE the diff looks slightly off centre and the breather is on the right looking from the rear.could i use it and does anyone know what it is out of or will it be too wide for a standard chassis.just one more is it only possible to use a mk1 or 2 steeringrack.any answers would be greatfull.as im sick of buying those yellow and green papers
Duncan
posted on 29/12/02 at 09:37 PM Reply With Quote
Hi Heyzee
I have just completed my chassis using only the book for reference and yes, some of the sizes are wrong. Answers to your questions are:
Yes, y is too short. Measure your finished distance between RU1 and RU2 for the correct length. Weld on extensions at the other side of RU1 and RU2 to extend y to the full chassis width - 42".
Z should be okay but it is better to wait until your axle and panhard rod are fitted to locate the best position and length for z.
R can be left out until your engine is fitted.
Your axle is about the correct width for a book chassis. It is probably an Anglia or Escort. I collect my Escort axle on Tuesday, I will measure it and send you the size.
It is best to use a Mk1 or MK2 Escort rack as it the correct width for the book chassis. These are readily available.
Hopefully this will help you.
Happy building,
Duncan.
ps, don't buy the yellow and green papers. Just read the relevant sections and note any useful telephone numbers you need
heyzee
posted on 30/12/02 at 08:23 AM Reply With Quote
thanks
thanx for the answers should be able to get on a bit now cheers
Mark Allanson
posted on 30/12/02 at 11:38 AM Reply With Quote
I don't know if it would be any help, I have just measured my Capri 2.0S axle, it is 52" between the backplates.
Does yours look anything like this?
Mark Allanson
posted on 30/12/02 at 11:40 AM Reply With Quote
If you want chassis plans without errors, get McSorely ones, if you havent got them, let me know and I will email them to you
Mark
interestedparty
posted on 30/12/02 at 01:38 PM Reply With Quote
Mark
Jim (McSorley) prefers people to get the plans and other info direct from his website
http://mcsorley.net/locost/
John
Mark Allanson
posted on 30/12/02 at 08:55 PM Reply With Quote
Wrist firmly smacked
Holds head low in remorse
interestedparty
posted on 30/12/02 at 10:04 PM Reply With Quote
My comment wasn't meant as a rebuke, trying to help a fellow locoster is never naughty.
John
Alan B
posted on 30/12/02 at 10:21 PM Reply With Quote
I know Jim pretty well, so I'll step in here
I'm sure Jim would not be upset at plans being e-mailed, but I'm sure he'd prefer visiting the site just to be sure you got the latest.
There....diplomatic enough?
Now kiss and make up....
Mark Allanson
posted on 31/12/02 at 12:07 AM Reply With Quote
Feelings not really hurt, I got the plans from a fellow locoster trying to help me out, I was simply reciprocating.
I found the plans really good except for the top angles on the m uprights and the n rails which I think he got the angles mixed up. I only wasted about 2' of steel apart from that they were brilliant.
The fellow locoster I am trying to help out is using a Capri axle, I have just finished modifying the plans to make it fit, it is not as simple as it seems, the offset of the pinion is quite extreem, and needs modification to the tranny tunnel to make fit.
There was a lot of post a while ago about how the Capri axle would fit without any modifications, I think by members who had not actually fitted this axle to a locost chassis. it proves you cannot beleive everything you read!
I hope Jim has not taken any offence, he is really making a difference to how we are making chassis's over here, hats off to him
Appologetically
Mark
Dick Axtell
posted on 31/12/02 at 12:51 PM Reply With Quote
I have fitted a Capri (Timken) axle to a "book" chassis, but haven't yet had the prop-shaft modded, so cannot trial fit yet. It looks as though there is a potential foul point towards the rear of the trans tunnel, on the driver's side. I reckon that by cutting out the 2 existing vertical 3/4 RHS members in that area, and re-siting them appropriately, I will be able to overcome this problem.
How did other Capri axle users solve this issue? What is the difference in diff offsets between Salisbury & Timken types?
Mark Allanson
posted on 31/12/02 at 06:12 PM Reply With Quote
Dick, I am using a Salisbury Atlas with a ratio of 3.77:1. The pinion is exactly 1" off the centre line when added to the width of the input flange adds up to a fair bit. The pinion also extends a fair way into the tranny tunnel to compound the problem Rescued attachment DCP_0259sml.jpg
Mark Allanson
posted on 1/1/03 at 01:24 AM Reply With Quote
has anyone completed a car with this setup, and found a more elegant solution than this?
Jasper
posted on 1/1/03 at 04:10 PM Reply With Quote
I'm using a Cortina axle which also has an offset diff. I just put it all in then built the tranny tunnel to fit around it - no probs. The drivers side is a little snugger now, but the seats I bought fit fine.
Dick Axtell
posted on 2/1/03 at 08:41 AM Reply With Quote
Mark,
Thanks for fully illustrating your reply. I can now see the extent of your problem. I'll try to get to a scanner (or digi-snap the chassis & diff) with my similarly problematic area.
Dick
Dick Axtell
posted on 3/1/03 at 05:41 PM Reply With Quote
OK Mark,
Here's the principal shot of my diff area. You'll see that there appears to be no interference problem right at the diff nose. However, at the next vertical trans tunnel upright, there will be a foul point with the prop-shaft.
I'll post the other pics in the photo files area. Rescued attachment Raxle2.JPG
Viper
posted on 3/1/03 at 06:29 PM Reply With Quote
Originally posted by Dick Axtell
OK Mark,
That pic shows an english axle which was fitted to escorts, Marks axle is an Atlas which you would find on capri's...the Atlas is considerably wider and the diff is built up in the casing whereas the english axle has the diff mounting into the front of the casing (diff is built up in its own casing) thats why its so muh easier to replace a diff on an english axle...I
Dick it appears to me if you are going to have a problem with clearance then perhaps something is out of alignment, perhaps it would pay you to go over it witha tape measure..
Hope this helps..
Dick Axtell
posted on 5/1/03 at 08:36 PM Reply With Quote
Originally posted by Viper:
That pic shows an english axle which was fitted to escorts, Marks axle is an Atlas which you would find on capri's...the Atlas is considerably wider Hope this helps../quote]
Thanks for the advice re the checking, Viper. Just to clarify the differences between these axles - mine came from a Mk2 (German-built) Capri 1600, although as you correctly identified, it was the "English", or Timken axle (all threads are UNF). What you refer to as the "Atlas" type seems to be called Salisbury type in the Haynes manual. Backplate-to-backplate dimensions should be identical (52 inches). The larger-engined Capris may have had yet another version of the axle.
The foul point on my chassis will only be verified when I try to fit the propshaft. Before that, I must re-locate the engine slightly forwards, to ensure clearance between bellhousing & bulkhead.
Dick
Viper
posted on 5/1/03 at 09:29 PM Reply With Quote
Dick.
salisbury is the diff, atlas is the axle, ford also used the atlas in mk2 rally escorts, though these are bloody expensive they are shortened versions and have fully floating half shafts and they called it the baby atlas, all capris manufactured after october 1976 were built in germany. are you sure it was a mk2 and not a mk1 ? i have never seen a mk2 with an english axle though i know when the mk2 was introduced the rear wheel track was widened! This has me intrigued as i have little experiance with mk1's how wide is your axle? If you havent guessed capri's have a place in my heart..
Mark Allanson
posted on 5/1/03 at 10:03 PM Reply With Quote
I bought my axle from a scrappy, he said it came from a 2.0S Mk3. I rang my local ford dealer with the casting number from the diff, and they said this casting was first used on the Mk1 Granada!!, but ford never update the casting numbers from the first application, the ratio is 3.77 or possible 3.75 (I counted), do you know which Capri this came from?
Dicks axle has mounts for an antirollbar, does this exclude the Mk1?
We are relying on you soft spot for Capri's for an answer
Mark
Viper
posted on 5/1/03 at 10:59 PM Reply With Quote
To the best of my knowledge all the 2.0 had 3.44:1 the 1.6 was 3.75.1 i am pretty sure the 2.0s had wider brakeshoes than the smaller engined cars.
Any use?
Dick Axtell
posted on 10/1/03 at 05:08 PM Reply With Quote
And they also provided much-modified bodyshells for rally specialists to build RWD Mk3 Escorts (using Mk2 running gear). Saw one in Evesham last year.
Viper
posted on 10/1/03 at 05:29 PM Reply With Quote
I don't think ford supplied modded shells it is people like Getrag (think that's how to spell it) who used to build such beasts, still are to the best of my knowledge.
interestedparty
posted on 10/1/03 at 05:37 PM Reply With Quote
Gartrac, actually, but you got very close! (Getrag are the german gearbox makers)
John
Viper
posted on 10/1/03 at 05:41 PM Reply With Quote
John
Hmmmmyou are bang on, must be all the alckiholl (my excuse and i am sticking to it)
New Topic New Reply
