Author: Subject: The Haynes manual Translated!
B3Saxo
posted on 9/1/03 at 01:22 AM Reply With Quote
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise.
Haynes: This is a snug fit.
Translation: You will skin your knuckles!
Haynes: This is a tight fit.
Translation: Not a hope in hell matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - thats the glass bit off, now fetch some good pliers to dig out the bayonet part.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing them re-check the manual because this can not be 'lightly' what you are doing now.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, tiny, 'ikkle number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more
use to you).
Haynes: Three spanner rating.
Translation: But Nova's are easy to maintain right... right? So you think three Nova spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride in it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search in the dark corner of the garage for whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark pugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to do!
Another quality post from B3Saxo!
kingr
posted on 9/1/03 at 11:45 AM Reply With Quote
Hehehe, now I have an impact wrench, the instruction "this is a tight fit" means, "crack out the impact wrench, find you're not getting anywhere, marinade in WD40, still find it won't budge, turn impact wrench to max power, round off bolt.
Kingr
Mark H
posted on 13/1/03 at 10:01 PM Reply With Quote
LOL - and so true!! I wish my Sierra was in the same condition as the one in the manual! But with about 140 thousand more miles on it, every nut and bolt is weld (not finger) tight.
And their overalls are pristine!
Mark Harrison and
Q986 KCP back from the dead...
jollygreengiant
posted on 13/1/03 at 10:51 PM Reply With Quote
350Nm air gun & a hot spanner. Nothing can resist that combination.
Enjoy
