Author: Subject: Escort rear axle brackets
P4
posted on 12/1/03 at 02:33 PM Reply With Quote
Can any onyone give me the dia of an Escort rear axle so I can make the fixing brackets.
Also I belive that MK do not us a mounting bracket for the rear lower suspension point as the book but use a longer bolt throught the top hole of bracket attached to the axel. If this is so can someone give me the measurements for mounting the brackets on the axle. ie from the centre of the diff.
P4
JohnFol
posted on 12/1/03 at 02:49 PM Reply With Quote
diameter is 65mm from memory.
Here is a blurred pic (sorry) of how mine looks
The distance from the center of the axle is deternined by hanging the shocks from their mount and seeing where they fall..
[Edited on 12/1/03 by JohnFol]
JohnFol
posted on 12/1/03 at 02:50 PM Reply With Quote
And with the attachment
