Author: Subject: Top wishbones
P4
posted on 19/1/03 at 02:07 PM Reply With Quote
Top wishbones
I have set the top wishbone mounting brackets to the book dimensions (204 mm between centres). With the bottom wishbone at 90 degrees to the chassis rail, the top wishbone is at an angle greater than 90 degrees to the top chassis rail (as it should be to correct the camber when cornering).
Can someone give me a measurement to check the top wishbone orientation before I weld the brackets? I need to know either the angle of the top wishbone or the height from the bottom wishbone to the top wishbone ball joint.
Thanks,
Ian
P4
