Author: Subject: ANY BODY GOT A HAYNES MANUAL FORD FOCUS..
GeoffB
posted on 14/10/05 at 10:59 AM Reply With Quote
NEED TO SET MY SPARK PLUG GAPS ON A 1998 1.8 FORD FOCUS , MY LOCAL DEALER IS HARD WORK..ANYBODY HELP..
IF YOU COULD COME BACK TO ME BEFORE I CHANGE THEM @18.00
TA VERY MUCH
Danozeman
posted on 14/10/05 at 12:13 PM Reply With Quote
All makes of plugs should be 1mm gap apart from NGK PTR5A-13's should be 1.3mm.
This came from autodata.
Dan
Messenjah
posted on 14/10/05 at 01:06 PM Reply With Quote
posted on 14/10/05 at 01:08 PM Reply With Quote
Donners90
posted on 14/10/05 at 02:37 PM Reply With Quote
1.3mm
Checked the Ford technical data manual and for 1.8 and 2.0L variants, gap should be 1.3mm. Assuming you are using Ford plugs. Plug model # AYRF-22PP
