Author: Subject: Formula for working out Liquid volume
cryoman1965
posted on 25/11/05 at 02:37 PM Reply With Quote
Anyone know how to work out the Liquid of a Fuel Tank.
Cheers Nige
posted on 25/11/05 at 02:40 PM Reply With Quote
Length x height x width (measured in cm)
Divide by 1000 to get litres.
Try doing that in inches and gallons!
P.S. Divide by 4.546 for UK Gallons
[Edited on 25/11/05 by David Jenkins]
cryoman1965
posted on 25/11/05 at 02:52 PM Reply With Quote
i should have paid attention at skool.
DarrenW
posted on 25/11/05 at 03:26 PM Reply With Quote
It gets complicated if you have less than simple shape. Depends how exact you want to be i suppose.
Dave J
posted on 25/11/05 at 04:03 PM Reply With Quote
Couple of measurement conversion sites you might find useful:
http://convert.french-property.co.uk/index.htm
http://www.onlineconversion.com/volume.htm
Dave
Volvorsport
posted on 25/11/05 at 04:18 PM Reply With Quote
make it out of carboard boxes , in the shape you want , line with bin liner - fill with measured water .
www.dbsmotorsport.co.uk
getting dirty under a bus
liam.mccaffrey
posted on 25/11/05 at 05:48 PM Reply With Quote
fill the tank with expanding foam then cut the tank open to get your foam tank negative out and then fill a bath with water to the brim and then plunge your foam tank negative into the bath and measure the volume of the water displaced, eureka!
seriously though either fill it with water or fuel if its installed, syphon out the liquid and measure it/weigh it
OR
if its not in the car weigh it, fill it up with fluid and weigh it again. you can work out the volume from the difference in weight
[Edited on 25/11/05 by liam.mccaffrey]
Build Blog
Build Photo Album
posted on 25/11/05 at 06:36 PM Reply With Quote
if its not a simple shape, just post dimensions - i love that sort of problem my favourites at gcse were working out the angles of tent posts from obscure areas etc
liam.mccaffrey
posted on 25/11/05 at 07:03 PM Reply With Quote
I really enjoy trig and stuff like that
Build Blog
Build Photo Album
posted on 25/11/05 at 07:16 PM Reply With Quote
i had to look it up on google when i had to do trig recently! Actually found a small program called machinists calculator that whipped it all up for me!
Mansfield
posted on 25/11/05 at 07:20 PM Reply With Quote
Give me dimensions and I will model it in AutoCAD. Give me our address and I will send you AutoCAD and you can model it yourself. Offer open to anyone.
steve_gus
posted on 25/11/05 at 08:42 PM Reply With Quote
100x100x100mm = 1 litre
If its an oblong or square, just multiply all the sides together and divide by a million - then you get litres.
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
omega 24 v6
posted on 25/11/05 at 08:43 PM Reply With Quote
If the tanks already made and you need to know the capacity measure the weight of the tank and then fill with water. Then subtract the original weight of the empty tank. 1 litre of water equals 1kg of weight so you can work out the capacity.
posted on 25/11/05 at 09:32 PM Reply With Quote
Umm... didn't I say that earlier on?
DJ
ReMan
posted on 25/11/05 at 10:34 PM Reply With Quote
Or fill it with milkbottles full of water, if you can find a milkbottle!
Divide the numer of milk bottles by 8 and thgen you've got gallons
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
steve_gus
posted on 25/11/05 at 11:45 PM Reply With Quote
yep, you did, as lxhxw.
I just made it easier to visualise what volume a single cubic litre actually occupied
so there
atb
steve
Ps - Also David, you are being anti american - you didnt give the US gallon fomula - there are certain people that pull you up on these things
so, its
3.7854118 litres per US gallon
DJ
[Edited on 25/11/05 by steve_gus]
posted on 26/11/05 at 07:59 PM Reply With Quote
COBBLERS!
steve_gus
posted on 26/11/05 at 11:35 PM Reply With Quote
yep. I should have perhaps used that answer too
atb
steve
posted on 27/11/05 at 12:56 PM Reply With Quote
That doesn't sound right!
Take an example tank - 10cm x 10cm x 100cm
This is 10000cc, or 10 litres, roughly 2.2 galls.(UK!)
Convert this to imperial - roughly 4" x 4" x 39"
Which is 624 cu in. Multiply this by 6.25 gives 3900 gallons!
The correct mutliplier is 0.0036047, which gives 2.25 UK gallons for the example tank (spot on, allowing for conversion errors)
I'll stick to metric, thank you...
[Edited on 27/11/05 by David Jenkins]
