tony9876
posted on 20/3/06 at 11:34 AM |
Ford Diesel Cambelt
Does anyone know(pictures would be great) where the blanking plug is situated to set the crank timing on a 98 ford diesel fiesta because I am buggered
if I can find it ?
Danozeman
posted on 20/3/06 at 11:46 AM |
On the front of the engine towards the bottom of the block behind the alternater.
There should be a hole through the alt/ ps pump mounting bracket. Its a 10mm bolt through there.
I cant remember if u have to take the alt off or not to get to it.
Set the timing hole on the pump to 11 o clock put the timing pin in the block and turn the engine till it cluncks. The hole should be at 12 oclock.
Thats it timed.
[Edited on 20/3/06 by Danozeman]
Dan
Donners90
posted on 20/3/06 at 12:43 PM |
As Danozeman says, its near the alternator. You'll have to take off the intermediate shaft....
theconrodkid
posted on 20/3/06 at 03:18 PM |
usefull tip no 10....put a magnet on yr socket,if you drop the plug you wont get it back....no need to remove alternator if you do it from
underneath
who cares who wins
pass the pork pies
tony9876
posted on 20/3/06 at 03:33 PM |
Its on 98 Fiesta and it looks totally differnet from the piccy. The only bolt behind the alternator is a 13mm and about 40 mm long in the centre of
the bracket.
[Edited on 20/3/06 by tony9876]
posted on 20/3/06 at 07:33 PM |
You need to look at the front of the alternator mounting , there is a hole about 19mm in dia . No need to remove alternator the bung is hidden inside
the alternator mounting.
theconrodkid
posted on 20/3/06 at 07:48 PM |
and do it exactly by the book,including loosening the cam /pump gears, warm up/cool down bit,QH do a kit with tensioners that you will need
oh and dont try to remove crank pully,the belt wil slip between the pulley/block if you turn it inside out
[Edited on 20/3/06 by theconrodkid]
who cares who wins
pass the pork pies
tony9876
posted on 20/3/06 at 08:46 PM |
I am going to have another bash tomorrow. Been at it a fortnight now and am soory i started. It takes about 4 hours of stripping before you can get at
where you need to and i still cant see the bastard plug.
Thanks for the info lads.
