block
| posted on 6/4/06 at 03:41 PM |
laguna tow bar
Anybody fitted one, had a quick look and it appears i need to remove the bumper. Seems a bit over the top. any help would be appreciated. Cheers.
ned
| posted on 6/4/06 at 03:57 PM |
had to remove the bumper on my bora, slotted into the rear subframe of the car easily though.
Ned.
beware, I've got yellow skin
flak monkey
| posted on 6/4/06 at 04:04 PM |
Done towbars on 3 or 4 cars now, and all have required the removal of the bumper. Its actually the worst part as they are usually held on with plastic
clips that are very tricky to get undone.
[Edited on 6/4/06 by flak monkey]
Sera
http://www.motosera.com
Peter M
| posted on 6/4/06 at 04:37 PM |
Just fitted a tow bar to my megane had to remove my bumber, initially it looked a pain but turned out to be very easy to do. All job from start to
finish about an hour.
| posted on 6/4/06 at 05:07 PM |
how hard is the wiring?! I fancy adding one to the legacy.
steve_gus
| posted on 6/4/06 at 06:42 PM |
yonks ago on a maestro i had to remove the bumper. nothing new there
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
k33ts
| posted on 6/4/06 at 07:16 PM |
what towbar have you got shouldnt need removing
have you got laguna 2 or 1?
tukcustoms.com
k33ts
| posted on 6/4/06 at 07:18 PM |
has a dedicated plug behind right rear panel tap into that
tukcustoms.com
block
| posted on 7/4/06 at 08:45 AM |
Cheers for advice. Its an 02 plate. Looks like ive got holes in chassis rails for 1 bolt, and 2 more on rear cross member of chassis, they are not a
captivated nut and you cant get behind without moving bumper. Will go and have a go, cheers.
