Jumpy Guy
| posted on 7/4/06 at 02:01 PM |
Beginners Sketchup questions!
All help much appreciated!!
Some simple things are elluding me-
1. how do i dimension a rectangle? i can obvioulsy use the move tool to stretch it to size. isnt there anywhere i can input (type) the lengths as a
number?
2. Isnt there an equivalent to the Trim tool in autocad? everytime i try to trim a line, then it deletes thw whole line..
thanks!!
CommanderAce
| posted on 7/4/06 at 02:14 PM |
1.
If you look down the bottom right-hand corner there is a little box with the current dimensions of the shape your're drawing. If you enter the
dimensions you want on your number-pad it will change to them!
2.
Not quite sure as I don't use AutoCad, but you can use the Section Pane tool and 'make a group from slice' then explode it.
Have fun
Pete
[Edited on 7-4-06 by CommanderAce]
Roads? Where we're going we don't need roads!
benson68
| posted on 7/4/06 at 02:45 PM |
To dimension a rectangle in autocad
1- click and drag the rectangle out
2- before finshing the rectangle with a second click type "@100,200"
100 being the dimension in X and 200 being the Y
Hope it helps
Jumpy Guy
| posted on 7/4/06 at 03:06 PM |
anyone know the price of Sketchup?
the website appears to be down...
Jumpy Guy
| posted on 7/4/06 at 05:13 PM |
another daft question-
how do i rescale a component, such as one of the trees in the library?
CommanderAce
| posted on 7/4/06 at 06:23 PM |
here watch these they are very good, you just
have to put up with their annoying voice!
