RazMan
| posted on 14/4/06 at 10:03 AM |
Incomplete Torrents
I've been downloading a movie from a BitTorrent site and it has stopped at 97.9% with no seeds (been like this for days now)
Is there any way to fill in the remaining 2.1% with blank data so that I can burn it to a DVD and put up with the gaps?
Raz
muzchap
| posted on 14/4/06 at 10:26 AM |
Unfortunately no :-(
The problem is every piece is hash # encoded - and CRC'd.
Have you tried searching other torrent sites for the same version? It might have been re-seeded elsewhere:
www.torrentspy.com
www.thepiratebay.com
etc...
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
chasmon
| posted on 14/4/06 at 01:38 PM |
Torrent incomplete.
You may be able to play the movie depending on what file type it is.
If it was compressed by winzip or winrar then no. If it was a AVI then you can however open it in VLC and play it on your PC.
VLC by videolan is a free player and very good at playing partial downloads.
To fix it you may be able to use something like VirtualDub or similar.
Hope this helps.
| posted on 14/4/06 at 04:34 PM |
Had similar problems with downloading large ISO files a few years back --- turned out to be MTU related, reduced the MTU and it sort of went away. I
am pretty sure part of the problem was an my ISP (BT-Yajoke).
Since then have switched to a decent ISP and never had to twiddle the MTU setting ever again.
[Edited on 14/4/06 by britishtrident]
RazMan
| posted on 14/4/06 at 05:22 PM |
It is an avi file but it won't play in Media Player or Nero. It isn't seeded anywere else as far as I can tell and there are over 9000
other people (leechers?) in the same boat. I'll give VLC a try - thanks chasmon
Raz
RazMan
| posted on 14/4/06 at 05:40 PM |
Just tried VLC and no luck
Raz
greggors84
| posted on 20/5/06 at 10:07 PM |
RazMan, did you ever sort this out?
Its just started to happen to me, really annoying!
What are the MTU settings?
Chris
The Magnificent 7!
RazMan
| posted on 20/5/06 at 10:32 PM |
In my particular case it turned out to be a spoof file - why anyone chooses to mislead people in this way is beyond me
I'm not sure what the MTU settings are but they are probably default.
I have found that I get the best download speeds at night (probably when the US wakes up) so I just get everything queued in Azureus and go to bed -
everything has normally finished downloading by the next morning, except for 4Gb film files which can take a few days.
Raz
