DaveFJ
| posted on 7/5/06 at 08:57 AM |
making ramps - your thoughts
I ahve been asked to make a pair of ramps for a electric disabled scooter thingy so it can be driven into the back of a vehicle. (I assume without the
driver sat on it!)
The ramps need to be 7feet long and 6-8inches wide. they need to either hinge in the middle for easy storage in the boot or the need to come apart.
The minimum weight they need to support is 85Kg
I was thinking of some ali treadplate with some right angle extrusion to give it strength. All rivetd together with structural rivets and PU'd
see scribble
I value the input of you guys so anyone got any suggestions ? any idea on thickness of material or the best places to get it ? any clever ideas for
the hinge/break point ?
cheers
[Edited on 7/5/06 by DaveFJ]
Dave
omega 24 v6
| posted on 7/5/06 at 10:51 AM |
Prolly best if we new the maximum weight!!!
The skid ramps on a brian james transporter are (optional) ally formed (extruded?) so you should in theory be able to make up somthing suitable.
As for the hinged area you can get heavy duty piano hinge but someone cleverer than me would need to work out if the shear strength og the hinge pin
was high enough for your application.
Good luck.
DaveFJ
| posted on 7/5/06 at 11:01 AM |
As I say - I think the buggy will only be driven up it without the driver sat on it so it just has to hold the buggy weight - which is 85Kg
The driver would add another 22 stone!!!     (that would be my dear old dad then....)
Dave
907
| posted on 7/5/06 at 11:17 AM |
Hi Dave
My thoughts are telescopic, something to do with your avatar I suspect.
Fold 4ft long section (local sheet metal shop???) as shown in pic
Fold 4ft long section slightly smaller so that it will slide inside the first one.
Job done
For.
Slide together for storage, extend to 7ft to use, i.e. 1ft overlap.
Use with folds facing upwards to stop wheels coming off the sides.
Against.
Far too low-tech with no *Bling* factor.
All the best mate.
Paul G
DaveFJ
| posted on 7/5/06 at 11:30 AM |
nice idea - but would need 3 sections because the overall stored length should be 3.5 feet to fit in the boot...
Dave
MkIndy7
| posted on 7/5/06 at 01:09 PM |
Could they not be stashed underneath the vehicle somewhere, they they won't have to be lifted in and out of the boot and the lengthhingeing
might not be so critical.
907
| posted on 7/5/06 at 04:28 PM |
O.K.
Two sections, 3'6" long.....
And park 5'9" from the kerb.
Paul G
DaveFJ
| posted on 7/5/06 at 06:50 PM |
love that logic
Dave
