zxrlocost
| posted on 19/5/06 at 09:55 AM |
can you buy an emissions reader for a laptop
hi as above can you buy a kit or something that reads emissions
save keep pissing around at MOT stations
ta chris
rayward
| posted on 19/5/06 at 10:03 AM |
halfords do a stand alone one, gunsons i think.
Ray
UncleFista
| posted on 19/5/06 at 10:04 AM |
ta chris
You can buy "hobby" ones but they're not very accurate. The profesional ones that garages use are expensive and need calibrating
every 6 months or so.
Quick answer = no
Tony Bond / UncleFista
BKLOCO
| posted on 19/5/06 at 10:20 AM |
Your best bet is a wide band lambda sensor and controller.
Innovations LC-1
This will allow you to directly read the air fuel ratio and tune accordingly.
I got my Zetec through SVA emissions of .45 at idle and .3 at 3000 with the aid of one of these. (and a cat)
I tuned the idle to 14.7 : 1 and 3000rpm (no load) to about 15 : 1 and made the map a straight line between the two and got through. Crazy realy
because the rest of the map can be as rich as f*** and poluting as hell and it doesn't matter.
Not cheap though.
£130 ish from Bill Shrivinton.
[Edited on 19-5-06 by BKLOCO]
zxrlocost
| posted on 19/5/06 at 10:50 AM |
hi that sounds complicated
chris it was pissing it down so I called it off
retest monday
trikerneil
| posted on 19/5/06 at 11:52 AM |
Have a look HERE.
it may be of interest
ACE Cafe - Just say No.
Syd Bridge
| posted on 19/5/06 at 12:02 PM |
ta chris
Take a look around the PICO website.
http://www.picotech.com/
Lots of good stuff for the PC and laptop to play with associated with cars.
Syd.
