svenkev
posted on 27/5/06 at 08:00 PM |
flower disc's
are there some builders intersted in disc's
like these
posted on 27/5/06 at 08:01 PM |
Very pretty. What do they fit and how much?
[Edited on 27-5-06 by Hellfire]
svenkev
posted on 27/5/06 at 08:15 PM |
these are for the mk indy with cortina
uprights
price depents on howmuch i have to make
house19uk
posted on 27/5/06 at 08:55 PM |
Will they fit a book locost with cortina uprights if so i would be intrested to know how much.
James
posted on 27/5/06 at 09:48 PM |
uprights
You'll be lucky to find many Indys with Cortina uprights!
James
[Edited on 27/5/06 by James]
- Muhammad Ali
andyharding
posted on 27/5/06 at 10:13 PM |
What's the point?
RazMan
posted on 27/5/06 at 11:26 PM |
quote: Originally posted by andyharding
What's the point?
I have to ask the same question.
Surely the swept area has to be inside the 'bite marks' so you might as well have a smaller (and lighter) disc to start with ...........
or am I missing something?
Raz
James
posted on 27/5/06 at 11:37 PM |
What's the point?
Rorty who uses them made some interesting points about them a while back...
IIRC the 'bumps' will sweep away any debris/swarf/pad dust that would otherwise get trapped in there and (presumably) cause scoring
etc.
Sorry if I've got that wrong Rorty!
James
- Muhammad Ali
TimC
posted on 28/5/06 at 12:12 PM |
I'll have a pair depending on cost (Cortina upright.) Would also like a matching set for sierra rear...
they just look cool!
wildchild
posted on 28/5/06 at 05:02 PM |
quite a few top end sports bikes are using 'wavy' discs. I think it has something to do with heat dissipation. Plus they look quite good
on a bike!
Don't know why you'd bother on a car where you can't see them.
TangoMan
posted on 3/6/06 at 09:00 PM |
NICE!!!
I might be interested depending on the price.
Not until I am back from LeMans though as funds are currently diverted.
posted on 4/6/06 at 09:02 AM |
Wavy disks on bikes are stainless steel and about 2mm thick and run sintered pads. Are these standard disks drilled and cut? Have you run any for any
length of time to test their longevity and efficiency, the hole near the bell looks redundant as it is outside the pad area.
