Author: Subject: pimp my bits is back!
omega0684
posted on 28/5/06 at 05:37 PM Reply With Quote
hi all,
after having another quiet week, i thought that it be time that i started to get back on track with the build, so this weekend, i want to get the engine and gearbox in so i can start to measure other bits and pieces up.
so here it is todays work, we have had series 1, "pimp my diff", so checking over the forum we havent had alot of pimpin for a while,
so now introducing series 2 "pimp my gearbox!" pic's below..
just got to put alloy bell housing on when i get one!
post your pictures guys
Alex
SeaBass
posted on 28/5/06 at 06:12 PM Reply With Quote
Just a quick question?? How much play should there be in the input and output shafts of a type 9??
I picked one up a while ago pretty cheap but there seems to be play in both the input and output shafts...
Macbeast
posted on 28/5/06 at 06:24 PM Reply With Quote
Very nice
What kind of paint ? hammerite ?
omega0684
posted on 28/5/06 at 06:27 PM Reply With Quote
yep, bog std hammerite, silver and deep green (BRG). couple of coats of both, and it comes up a treat, the hardest part is cleaning up the gearbox before painting, lots of ground on dirt very hard to get off, but look at the result
just measured, output shaft has 10mm play in it, and the input shaft had about 40mm of splined shaft before you hit the clutch leaver, hope this helps
ATB Alex
now im going back to the garage cuz i just noticed i've missed a bit
[Edited on 28/5/06 by omega0684]
CairB
posted on 28/5/06 at 10:01 PM Reply With Quote
I'd just check that the small hole in the dome on the gearbox cover isn't blocked as this is the breather.
If this is blocked then the seals will have a hard time due to the gearbox becoming pressurised when it warms up.
Colin
