James
| posted on 3/6/06 at 10:23 PM |
Tin Top probs- 1.8 205 Diesel! :D
Right, firstly this ain't my car!!!!
Friend of mine has just bought this wonderful piece of 1992 Gallic engineering marvel-dom.
5 days after getting it, it's developed a problem.... the engine won't turn off!!!
I know nothing about Diesel's (or car's in general... thanks Ned! ) so wouldn't know where to start looking but any ideas about
what could be wrong? Is it just a case of ignition switch being dicky?
I owe him a few favours so it'd be nice to pay him back a bit!!!
Thanks,
James
[Edited on 3/6/06 by James]
- Muhammad Ali
theconrodkid
| posted on 3/6/06 at 10:28 PM |
on ze injection pimp est la solenoid,posibility missure ze pistione est sucked et needs clumping avec grand hammer
who cares who wins
pass the pork pies
UncleFista
| posted on 3/6/06 at 10:44 PM |
I'll second le conrod kids diagnosis
It's on the injector pump, usually has a button on it saying STOP, that's the manual fuel cut-off. At least it was on my Cav-pumped 405
Tony Bond / UncleFista
Fozzie
| posted on 3/6/06 at 11:22 PM |
Try replacing ze shut orf valve on the fuel pump (its a solenoid operated valve).
I have it on good authority thats the problem! (Exact same happend to Stu).......
Fozzie
Note to self.....read previous replies properly!
gazza285
| posted on 4/6/06 at 04:55 AM |
Unless it's really knacked and running on the engine oil, does it smoke at all?
theconrodkid
| posted on 4/6/06 at 06:12 AM |
gazza,its french,what do you think!
who cares who wins
pass the pork pies
| posted on 4/6/06 at 07:45 AM |
Of course not , they go forever. Just replace the solonoid Make sure you get the correct one as I think there may be a choice of pumps . Decent motor
factors should be able to help or a desiel specialist . Do not get from main dealers!
Agriv8
| posted on 4/6/06 at 10:36 AM |
I had a zx 1.9 another marvell of frenchness. same engine as the the pug the 1.9 xud unit
enging and gearbox were fine everything else rattled off.
Mine used to do this from time to time. I found that it would get build up of crud under where the celanoid sealed the deisel off. which was a worry
as it was after the filter.
regards Agriv8
jollygreengiant
| posted on 4/6/06 at 09:04 PM |
Last Tuesday I had my come-upence for the previous weekend (see earlier post about should I have done lottery) cos my 406td taxi finally decided to
have a woblble just before going into blackwall tunnel (london) when the gearbox decided to throw a bearing wobble. Still after 245900 miles I supose
I shouldn't complain too much (we haven't touched / removed the gearbox at all since it came on the fleet at 90000 miles, might even have
the original clutch?
But yes replace the fuel shut off valve on the injection pump (8mm nut for electical connector & I forget what size for the solenoid). If it was
running on oil then revs would probably keep on rising.
James
| posted on 6/6/06 at 03:47 PM |
Thanks for the advice everyone.
Have passed it on to my mate.
James
- Muhammad Ali
ned
| posted on 6/6/06 at 04:10 PM |
James there is a specialist bosch/pump place on slyfield if its of any help, possibly for advise or parts.
Ned.
beware, I've got yellow skin
Danozeman
| posted on 6/6/06 at 05:54 PM |
Deffo the fuel solenoid. As rusty said dont get one from a dealers they cost a fortune!!
Dan
