Author: Subject: painting discs
dilley
posted on 11/6/06 at 08:11 PM Reply With Quote
painting discs
not the friction surface!!
Im fed upwith seeing rust on my discs, will engine laquer stay on the hub area of discs or will it just turn messy?
INDY BIRD
posted on 11/6/06 at 08:15 PM Reply With Quote
I always do mine with smooth hamerite.
stays on and always looks good.
tom windmill
posted on 11/6/06 at 10:06 PM Reply With Quote
yeah smooth hammerite here aswell, looks tons better!!
Fred W B
posted on 12/6/06 at 05:53 AM Reply With Quote
I use high heat resistant flat black paint as sold for painting exhaust pipes
Fred W B
posted on 12/6/06 at 09:03 AM Reply With Quote
We have used Foliatec (2 Pack) Brake Caliper Paint. It's resistant to Brake Fluid and resist's high temperatures so we have put it onto our disc's too without much discolouration. Under extreme heat is does go 'off' a little, which you would expect it to.
It's remained on for ages and we have also painted the Oil Sump with it, brake master cylinder without any problems. It is quite expensive (around £20) but this will cover all 4 (front and rear) Sierra calipers and non-face disc surfaces 3 times.
HTH Steve
