Author: Subject: Some people must be smoking odd substances.......
Browser
posted on 14/6/06 at 01:47 AM Reply With Quote
....when they post ads on Ebay. Have a gander at this snippet, taken from an ad for a storage box to fit to the front of a trailer tent:
"MADE OUT OF GRP (glass reinforced plastic - fibreglass) WHICH IS STRONGER THAN STEEL BUT MUCH LIGHTER AND FITTED WITH A SECURITY LOCK AND KEY (2 keys supplied)"
Stronger than steel eh? SO if you smack a 5mm sheet of steel with a hammer it shatters does it? And you can make roll cages out of GRP can you? Eejit!
mangogrooveworkshop
posted on 14/6/06 at 02:04 AM Reply With Quote
Why try to dazzel them with diamonds when you can baffel them with bullshit!
Danozeman
posted on 14/6/06 at 05:35 AM Reply With Quote
Excactly!!!! There are some exceptionaly dim people about.
Dan
iank
posted on 14/6/06 at 08:38 AM Reply With Quote
It rather depends on the construction of the box, but I presume he's quoting tensile strength pub talk rather than impact resistance pub talk.
At the risk of being called an eejit/dim, weight for weight GRP (parallel roving) can have a rather higher tensile strength than mild steel.
GRP Parallel Roving - 550-900 MPa
Structural steel ASTM-A36 - 650 MPa
refs:
http://irc.nrc-cnrc.gc.ca/pubs/cbd/cbd205_e.html
http://en.wikipedia.org/wiki/Tensile_strength
Hitting a 5mm sheet of steel and a 5mm piece of GRP isn't a very fair test of strength anyway IMO.
posted on 14/6/06 at 09:09 AM Reply With Quote
Originally posted by iank
I
But it's what a villain would do if he wanted to steal the tools...
iank
posted on 14/6/06 at 10:14 AM Reply With Quote
I
A fair test of the material choice for a tool box yes, not for comparing GRP to steel strength. If the box was built from 25mm thick GRP roving built up in layers (similar weight I think) it would be a fairer test and I'd guess a closer result even on impact testing
Browser
posted on 14/6/06 at 06:55 PM Reply With Quote
I was thinking more it's ability to resist being dropped
trogdor
posted on 14/6/06 at 09:23 PM Reply With Quote
i am not sure if steel or fibreglass is stronger, but they differ majorly in their physical properties. ie steel as an metal is mallable, so it will absorb shocks as dents etc, where as glassfibre isn't mallable as will absorb shock up to the point where it will shatter.
i believe Glassfibre absorbs smaller shocks better than steel, ie no dents etc but will shatter and fail well before steel will.
however it all depends on the construction of said objects and materials! ideally u would want it made out of titanium!
[Edited on 14/6/06 by trogdor]
Browser
posted on 14/6/06 at 10:11 PM Reply With Quote
Titanium? Naaah mate, unobtanium's much better
iank
posted on 15/6/06 at 08:05 AM Reply With Quote
Nice thick rubber with steel bands inside for the best of both worlds
Other things to think about are corrosion resistance and the 'dropped it on my foot' weight test
trogdor
posted on 15/6/06 at 10:57 AM Reply With Quote
actaully titanium is one of the most aboundant minerals on the earth, for metals only iron has a greater amount. this in thery means it should be cheap as its very easily found within its ore.
unlike iron which is easily removed from its ore, titanium requires an expensive method to enable extraction. i can't quite remember off the top of my head but it uses expensive and toxic chemicals as well as aluminum. this is another reason why its expensive, as bauxite, aluminum's ore is not that common and is also not cheap to extract.
if someone could come up with an cheap extraction method they would be very rich as this method is highly sought after
apoligies for wandering, i always like to use my a level knowledge whenever i can, makes it feel like it was worthwhiile!
[Edited on 15/6/06 by trogdor]
