Author: Subject: Alloy header tanks
omega0684
posted on 17/6/06 at 10:58 AM Reply With Quote
Alloy header tanks
hi all,
i was just thinking whether or not an alloy header tank will pass SVA or not, surely with an alloy header tank you cannot see you water lever, where you can with the plastic ones obviously, how would you know that your water is low, is it a case of just checking every time you go out or do you have to install a sensor like on the brake fluid reservoir?
ATB Alex
ReMan
posted on 17/6/06 at 11:02 AM Reply With Quote
Theres no requirement to see water level, nor oil or fuel level for that matter.
Jasper
posted on 17/6/06 at 11:03 AM Reply With Quote
Fine for SVA - and just check it ocassionally
indykid
while having no water will make your engine overheat and possibly seize, it won't put you head long into a wall or hedge like a lack of brake fluid will.
if you have a radiator with expansion cap, you still can't see the water level, but it is expected to be checked with vehicle maintenance. it's not mission critical though, so needs no warning.
hth
tom
omega0684
posted on 17/6/06 at 11:34 AM Reply With Quote
cheers fella's
