Tricky Dave
posted on 4/7/06 at 01:09 PM |
Spark plugs different colours
Hi
The e36 325 engine in the viento has been idling roughly, and I've had a fault code 16: "Camshaft ignition sensor or ignition pulse. Check
spark plugs, coil packs and camshaft position sensor"
The plugs were new, so I've tried everything else (to no avail), but came to pulling them last night. Found that most were a (normal?) browny
dusty colour, but cylinders 1 and 5 were very white.
Presumably this means these cylinders are running lean and therefore hot? If so, what could cause this? I'm thinking either vacuum leak on the
inlets for these cylinders, or clogged injectors?
The exhaust headers for these two do get hot at idle, so something's going right...
Cheers!
DIY Si
posted on 4/7/06 at 03:30 PM |
If all the other cylinders are good, then probably a vacuum leak, or manky injectors. The headers will get hot if its running lean, even more so than
normal, since a lean engine/cylinder runs hotter than normal. Do you have a common air filter or one for each cylinder? Could be two are clogged if
they're seperate.
Tricky Dave
posted on 4/7/06 at 03:42 PM |
Common filter.
Can't see how I'd get a vacuum leak on just those two, but have splashed £4 on 2 new inlet / head seals to check tonight.
I've got another one of these engines, so I think I'll be swapping a few injectors round if the seals are OK.
Am I right in thinking this cold be causing the rough idling?
DIY Si
posted on 4/7/06 at 04:20 PM |
Could do yes. If two run lean, they unbalance things a little, and could upset the idle.
