Author: Subject: Saxo Timing Belt
andylancaster3000
posted on 10/7/06 at 12:33 PM Reply With Quote
Saxo Timing Belt
I've just been asked if I would like to do a cambelt change on an early 1.0l saxo for a few beer tokens by a friend. I was just wondering if anyone has done one before and knows if there are any complications or special tools required etc before I jump in and agree to do it.
Andy.
posted on 10/7/06 at 12:53 PM Reply With Quote
Andy,
Should be a Pug/Citroen TU series engine in which case there's nothing special required to do the job other than small hands/arms - it's pretty tight in the engine bay. You may need to take off the wheel and remove a plastic wheel arch liner to get proper access.
HTH,
Nick
GazzaP
posted on 10/7/06 at 12:55 PM Reply With Quote
No should'nt need any special tools just mark the top and bottom pulley from when the belt comes of and refit the new belt, The tensioner has a square cut out in it which i usually just stick a socket drive in and tighten that way. There should be a hole in the block near where the crank sensor is and this should be used to lock the flywheel with a dowel pin or drill bit bit i've never used it,
Hope this helps
Gary
www.gmpmotorsport.co.uk
minordelay
posted on 10/7/06 at 12:57 PM Reply With Quote
Should be fairly easy job for a locoster. With the covers off pin the flywheel and cam pulley to lock it up. Only tricky part will be to remove crank pulley, 22mm bolt I think, tensioner is easy and don't overtighten the belt if it sings it's too tight.
Drop me a line if you need autodata pics.
andylancaster3000
posted on 10/7/06 at 03:32 PM Reply With Quote
Ok, I might well take her up on the offer then.
Don't suppose people know if it's an interference engine or not do they??......Just in case!
Ketchup
posted on 10/7/06 at 04:54 PM Reply With Quote
change the tensioner too while you are at it, i have seen more failures due to them giving up than the belts snapping, for the sake of another £10, will give u peace of mind.. and yep im pretty sure they are an interference engine
posted on 10/7/06 at 06:44 PM Reply With Quote
Interference engine for sure !
