Author: Subject: slipping clutch on a clio
posted on 20/7/06 at 10:41 PM Reply With Quote
my friend has a clio, and the clutch has started slipping all of a sudden. It still bites fractionally at the very top, but not enough to drive. The way it came on fast leads me to think its cable related. The clutch lever feels solid still, but the cable can be pulled a lot, and it squeeks from the pedal end. Still pulls itself back in though. Im guessing the adjuster is buggered, not letting the cable back far enough to bite. Anyone familiar with this one, and what does it need to fix it? Dissemble and mess with it? Or just scrap the damned thing, as its only worth a few hundred....
Any pointers appreciated!
in fact ive just decided its probably the engine end thats stuffed, as a strong clutch spring should easily pull the cable back if i can do it with two fingers....
[Edited on 20/7/06 by JoelP]
posted on 21/7/06 at 08:15 AM Reply With Quote
I had a Clio 1.9 diesel and the cable kinked where it goes through the bulkhead because of the soundproofing and eventually broke. I fitted a new cable and cut some of the stuff away and the clutch became twice as easy to press.
cloudy
posted on 21/7/06 at 09:52 AM Reply With Quote
My first car (a nissan sunny), went from driving normally along the motorway to suddenly revving its nuts off and having to limp home gently, in a few minutes. It was the clutch worn, so it can come on pretty fast
James
www.warnercars.com
