mookaloid
| posted on 24/7/06 at 11:45 AM |
Punto problem
A bit off topic but has anyone replaced the swinging arm bearings in a punto ('98 vintage)?
It looks as if I can just take the long bolt out, drop the arm down and replace the bearings 'in situ' without taking the whole thing off.
Is this possible?
Thanks in advance
Mark
| posted on 24/7/06 at 11:59 AM |
never been anywhere near a punto, but that sounds like Haynes pseak to me - i.e. far too easy
froggy
| posted on 24/7/06 at 12:18 PM |
are we talking rear arms here? if so change the whole arm around 30 quid a piece ,
mookaloid
| posted on 24/7/06 at 12:37 PM |
Really? I've just paid £25 for a repair kit
froggy
| posted on 24/7/06 at 12:55 PM |
im in the trade and and a new arm is 15mins to fit you might find the kit takes a bit longer
mookaloid
| posted on 24/7/06 at 02:20 PM |
What is the procedure?
jollygreengiant
| posted on 24/7/06 at 03:59 PM |
Get new arm, bolt & nut from dealer (£30 ish).
Jack car up, remove road wheel, remove brake drum, undo brake hose mounting plate, release brake cable from arm, undo brake back plate from arm, undo
lower damper mounting from arm, undo nut from long bolt. Remove long bolt, remove old arm & discard.
Pick up new arm, raise into place and fit new bolt & nut. Refit & retighten as in removal but reverse order.
J.D.
Have yourself a nice cold beer to congratulate yourself on a job well done.
mookaloid
| posted on 24/7/06 at 10:00 PM |
Thanks JGG I'll just fit the repair kit and pretend it's a new arm
