Author: Subject: Petrol Strimmer tank leaking
Avoneer
posted on 3/9/06 at 09:15 PM Reply With Quote
There are two small plastic pipes that just push into the bottom of the plastic petrol tank on the strimmer I have borrowed.
Problem is that one of them drips petrol out.
Anyone any suggestions to get or make a good seal?
Ta,
Pat...
DIY Si
posted on 3/9/06 at 09:19 PM Reply With Quote
Just use it quickly and gve it back! Or put a jubilee clip on it.
Sun Tzu, The Art of War
Avoneer
posted on 3/9/06 at 09:59 PM Reply With Quote
Nothing to jubliee around.
The soft pipe just psuhes through a hole in the bottom of the tank and sticks up inside the tank a couple of mm.
A bolt on nipple may be a good solution if you can get such a part ???
Pat...
MkIndy7
posted on 3/9/06 at 10:21 PM Reply With Quote
Might find something useful like a bulkhead connector in a Model shop if there's one anywhere near you.
carlgeldard
posted on 4/9/06 at 06:28 AM Reply With Quote
Can we not replace the pipe It may have age hardened and cracked. It's been sat in the garage for 5 years at least
Carl
Marcus
posted on 4/9/06 at 08:29 AM Reply With Quote
Did PTM make it?
Marcus
Because kits are for girls!!
