Tiger Super Six
| posted on 13/11/06 at 05:46 PM |
Excel Calculation
Guys,
I have a list of lap times that I want to put in a spreadsheet and then at the end add up to the minutes and seconds taken as the total.
For example: -
Lap 1: 32 sec
Lap 2: 32 sec
Lap 3: 32 sec
Lap 4: 32 sec
Lap 5: 32 sec
Lap 6: 32 sec
Lap 7: 32 sec
Lap 8: 32 sec
Lap 9: 32 sec
Total: 288 sec
If you divide this by 60 then you get 4.8 which is 4 full mins and .8 of a minute.
I want it in the actual time taken, which is 4mins 48secs (the actual time) - what is the excel calculation for this?
I am sure I am missing the point, but it's annoying me now!!
Mark.
Mark
Tiger Avon
caber
| posted on 13/11/06 at 05:50 PM |
Try changing to time value in format/ numbers menu
Caber
Humbug
| posted on 13/11/06 at 05:55 PM |
You need to format all the cells with time in (the individual lap times and the total) as time:
Format->Cells, select Time, then select a time format and click OK
Alternatively, to get rid of the hours, do Format->Cells, select Custom, type in mm:ss;@ and click OK
You then have to enter the individual lap times in hh:mm:ss format (hours, then :, then minutes, then : then seconds). So, for your example, type
00:00:32 and hit Enter.
In the total field, put sum(A1:A9) (or whatever the cell references are)
HTH
tlalli
| posted on 13/11/06 at 05:56 PM |
Press CTRL+1 to get to the format menu.
Custom number format should be hh:mm:ss
stevebubs
| posted on 13/11/06 at 06:23 PM |
This should help
TangoMan
| posted on 13/11/06 at 07:18 PM |
And another version!!
I love a challenge so just knocked this one up.
Easy entry gives total minutes and seconds.
Just enter the munites and seconds down the left hand side andthe blue totals gives you minutes and seconds.
Summer's here!!!!
Tiger Super Six
| posted on 14/11/06 at 09:21 AM |
Excellent - cheers for your help guys. I was setting it to the correct format but then putting a . instead of : as the seperator, so it wasn't
working
Yep, I'm dumb
Mark.
Mark
Tiger Avon
