<<  1    2  >>
Author: Subject: Anyone good at Maths?
Gav
posted on 18/11/06 at 07:32 PM Reply With Quote
Would i be right in saying that
1/3(x+2)^2-12 = 2/3x^2+2x-12 ?
[Edited on 18/11/06 by Gav]
posted on 18/11/06 at 07:37 PM Reply With Quote
do you mean:
(1 / (3(x+2))) squared
or
(1/3 (x+2)) squared?
first is equal to 1/(3x+6) squared which surely is 1/(9x^2+36) edit, actually 1/(9x^2+36x+36)
second is (x^2+2x+4)/9
unless ive forgotten how to square fractions.
thats obviously ignoring the -12, which is the same on both sides.
[Edited on 18/11/06 by JoelP]
DIY Si
posted on 18/11/06 at 07:41 PM Reply With Quote
Don't think so.
Any way you could write out what you mean and show it on here? It would be much easier to understand that way.
[Edited on 18/11/06 by DIY Si]
Sun Tzu, The Art of War
matt.c
posted on 18/11/06 at 07:46 PM Reply With Quote
What the?
lost me big time!
Gav
posted on 18/11/06 at 07:50 PM Reply With Quote
ok i need to get 1third times (x+2) squared - 12 into a quadratic ie ax squared + bx + c
arrybradbury
posted on 18/11/06 at 07:51 PM Reply With Quote
The straight answer is no (i think):
Thought as:
(x+2) squared multiplied by 1/3 and then subracting 12 gives:
(1/3 * (x^2 + 4x + 4)) - 12
= (1/3 * (x^2 + 4x + 4)) - 36/3
= 1/3 * (x^2 + 4x - 32).....
any help??
DIY Si
posted on 18/11/06 at 07:54 PM Reply With Quote
easiest way to show it, without lots of fractions in it is 1/3 * (x^2 + 4x - 32 )
1/3 * (x+2)^2 - 12
1/3 * (x^2+4x+4) - 12
1/3x^2 + 4/3x + (4/3 -12)
1/3 x^2 + 4x/3 - 32/3
3 answers and we all agree!
DIY Si
posted on 18/11/06 at 07:55 PM Reply With Quote
Or as an open thing 1/3x^2 + 4/3x -32/3
posted on 18/11/06 at 07:56 PM Reply With Quote
i edited mine due to the confusion over 4/3x and 4x/3, technically the same thing but it can be read wrong!
Gav
just eating my tea, ill give a smartie point to the correct answer, ill work it if its right for my parabola after tea
DIY Si
posted on 18/11/06 at 07:57 PM Reply With Quote
True, that's why I put it the first way first. Leaves less to the imagination.
DIY Si
posted on 18/11/06 at 07:58 PM Reply With Quote
If you can post a graph of the parabola with a few important point son it, we can probably get you the answer before you've finished your tea.
owelly
posted on 18/11/06 at 08:02 PM Reply With Quote
Is the correct answer 2 hats?
http://www.ppcmag.co.uk
Gav
posted on 18/11/06 at 08:14 PM Reply With Quote
parabola:
ok the problem i have is that when i converted the equation 1/3(x+2)^2 - 12 to a quadratic i found the to x-intercepts to be 4.3 and -9.7 which is close but obvisouly not right!
edit: yes im trying to prove the x-intercepts are correct.
clanger
posted on 18/11/06 at 08:15 PM Reply With Quote
too long ago without a trip to the attic, but my attempt
x^2+4x-6 ..............??????
car building and maths questions...wot a site
DIY Si
posted on 18/11/06 at 08:20 PM Reply With Quote
does it bottom out at -12, -2?
Gav
posted on 18/11/06 at 08:25 PM Reply With Quote
The vertex is correct at -2, -12
Just found another example which is correct:
-2(x-1)^2 + 1 = -2x^2 + 4x -1
its factorising i suck at, especially when fractions are involved :S
DIY Si
posted on 18/11/06 at 08:29 PM Reply With Quote
The equation is, I think, 1/3 x^2 + 4/3 x - 32/3
Or, 1/3 * ((x +8)(x -4))
Gav
posted on 18/11/06 at 09:13 PM Reply With Quote
You were close but not quite right
Answer is 1/3x^2 + 4/3x - 12
which gives -8.234 and 4.324 which if you look at the parabola looks just about right for the x-intercepts
DIY Si
posted on 18/11/06 at 09:16 PM Reply With Quote
can't be -12, or it would cross the y axis at -12! Instead it crosses at -10 2/3.
Besides even if i am wrong (and it's been known to happen), it's the first bit of algebra I've done since A levels, which was 4 years ago.
Gav
posted on 18/11/06 at 09:21 PM Reply With Quote
Actually you are right
Answer is 1/3x^2 + 4/3x - 32/3 which gives -8, 4
Which was first seen on the first page by joel
DIY Si
posted on 18/11/06 at 09:24 PM Reply With Quote
Also why I put it in the form above, as it makes finding the crosses easy, as you just have to make either bracket equal 0 to find the two, ie -8 for the first bracket and 4 for the second.
Gav
posted on 18/11/06 at 09:27 PM Reply With Quote
a well at least ill sleep well tonight after ive finished this bottle or brandy to cure the headache this gave me
Gav
posted on 18/11/06 at 09:32 PM Reply With Quote
Forgot to say, thanks for the help chaps
<<  1    2  >>
