Author: Subject: Golf GTI Mk4 leak
givemethebighammer
posted on 25/11/06 at 09:42 PM Reply With Quote
Golf GTI Mk4 leak
Can anyone help, my friend has an "S" reg 150BHP Golf GTI MK4 and there is water getting in to the left hand side of the boot from somewhere. He's taken a look and can't see anything obvious. I seem to remember reading that this was a common fault on these?
thanks
jacko
posted on 25/11/06 at 09:48 PM Reply With Quote
Rear window washer pipe leaking ?
i had this on the wife,s corsa
andrews_45
posted on 26/11/06 at 09:18 AM Reply With Quote
I got the same problem on my mk4 golf, it is a common quirk for the model
andrews_45
posted on 26/11/06 at 09:19 AM Reply With Quote
forgot to say, its the pipe coming off the union...
posted on 26/11/06 at 09:55 AM Reply With Quote
Interesting - I'm currently minding my daughter's S-reg GTi, and the other day I found that the rear nearside passenger footwell was soaking...
I wonder if this is a similar problem...
Agriv8
posted on 26/11/06 at 11:15 AM Reply With Quote
front carpets wet can be the drains at the rear of the top engine bay scutle ( where the wipers sit ) had this on my pasat. it was filling up and leaking down where the loom goes into the car drains were blocked with leaves a prodeler and the hose pipe.
regards
agriv8
posted on 26/11/06 at 07:52 PM Reply With Quote
Rear footwell...
givemethebighammer
posted on 26/11/06 at 07:56 PM Reply With Quote
thanks people
I also found out it can be the sunroof drain pipes that cause the problem.
http://forums.vwvortex.com/zerothread?id=1909676
http://forums.vwvortex.com/zerothread?id=2115848
