| posted on 9/12/06 at 12:25 PM |
Bonded Windscreens
Anyone know where I can get the sticky stuff required to bond in a new windscreen. I'm in the north east and need it fairly quick like today!
Anyone know what its correct name is and where to get it please???
| posted on 9/12/06 at 12:30 PM |
I know Car Builder Solutions sell the stuff but they're based in Kent.....
http://www.nfauto.co.uk/windscreen_bonding_kit.htm
Places like RAC Windscreen use the stuff but unless you managed to blag some, they probably wouldn't sell it to you. Have you tried a local
independant windscreen place?
You could also try getting in contact with places that make architectural sheet glass windows / walls (ie the fricking huge ones)- they're often
bonded in place into the frame for extra strength and they're not going to use any old stuff when the windows are often partially
structural...
[Edited on 9/12/06 by BenB]
macspeedy
| posted on 9/12/06 at 12:40 PM |
silkaflex , is an adhesive silicone available at keyline supplies very very very sticky stuff !
| posted on 9/12/06 at 12:51 PM |
It is sticky but its not the proper stuff. Sika sell their own brand of windscreen adhesive.
I suppose it depends upon the use its being put to. On a car with a structural windscreen I wouldn't trust it- even just from a point of view of
the windscreen firming up the chassis and making the ride better- Sikaflex is flexible- not great! On a kit where the chance of the windscreen not
collapsing if you flip it is pretty slim I might be tempted....
RazMan
| posted on 9/12/06 at 01:00 PM |
You can get the packs on eBay - 'Wurth' is the trade name and consists of cleaner, primer and adhesive. Much much stronger than Sikaflex
too and designed for windscreens.
Here is another
alternative
[Edited on 9-12-06 by RazMan]
Raz
robertst
| posted on 9/12/06 at 02:02 PM |
i thought silicone bathroom sealant was more than enough!
Tom
| posted on 9/12/06 at 02:11 PM |
COREdevelopments
| posted on 9/12/06 at 02:14 PM |
if you used a silicon bathroom sealer the windscreen would pop out pretty quickly, the bonding stuff he mentions is a far superior bonding
application, not a sealer. wurth product is expensive and is very good stuff as with all wurth products,
mookaloid
| posted on 9/12/06 at 06:01 PM |
Please put a big warning sticker on the windscreen if you do this!
It should say something like
UNSAFE TO DRIVE DODGY WINDSCREEN!!!
iank
| posted on 9/12/06 at 08:35 PM |
To be fair the OP doesn't say it's for a tin-top. Locost screens aren't bonded and using silicone sealant isn't a problem.
robertst
| posted on 10/12/06 at 12:49 AM |
IIRC the so called "bible" or "book" says to use bathroom silicone sealant for the windscreen....
Tom
mookaloid
| posted on 10/12/06 at 01:04 AM |
Well the title of the thread says Bonded Windscreens....
I took it to mean that Coozer was looking for the correct stuff for glueing in a Bonded Windscreen - ie one that actually relies on the glue to hold
it in - flush fitting glass in a tintop etc.
I'm sure any old sealer would do for a seven type screen in an ally frame.
Have a nice day
Marcus
| posted on 19/12/06 at 09:21 AM |
I always thought that the way to appear professional, was to spell professional correctly
Marcus
Because kits are for girls!!
iank
| posted on 19/12/06 at 09:24 AM |
I always thought it unprofessional to pretend you were a customer while posting using the companies user-name.
