flathatmat
| posted on 12/1/07 at 08:10 PM |
O/T Peugeot 307 airbag diconnection??
Anyone know how to disconnect the drivers airbag on a pug 307 as i have to remove it to get to a faulty horn switch? Or if anyone has had the same
trouble please share.
theconrodkid
| posted on 12/1/07 at 08:22 PM |
disconnect battery and have a nice cuppa for an hour or so while the capacitor drains down,wear a crash helmet just in case,ive removed loads and
never had a problem
who cares who wins
pass the pork pies
| posted on 12/1/07 at 08:28 PM |
Look at the back of the horizontal spokes, there is a small hole in each one . Use a coople of screwdrivers inserted into holes and pushed against a
spring {you have to feel for them} Pull the airbag from the wheel , 2 small connections and its off
flathatmat
| posted on 12/1/07 at 08:40 PM |
So the battery needs to be disconnected and then wait for 1 hour then insert a couple of screwdrivers into the access holes at the rear of the
steering wheel and feel for a spring fastener??
Is that all there is to it apart from eyes tight shut and bottom clenched??
[Edited on 12/1/07 by flathatmat]
