Author: Subject: Sky + again
davrus
posted on 21/1/07 at 08:21 PM Reply With Quote
Sky + again
Greetings
As you are probably aware i have just had sky+ fitted so still learning. Wife works nights so wants usual soaps recorded, well the thing is i got 5 mins in to her program before i realized i had not set it to record, i know it is a bit late now but for future ref is there any way i can press record after the program has started and get it to record it from the begining rather than from when i hit the record button.
Many thanks
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
posted on 21/1/07 at 08:23 PM Reply With Quote
As long as your watching the program it will record from the beginning.
Make sure your instant record is set to 1 hour. My installer recommended that.
ned
posted on 21/1/07 at 08:31 PM Reply With Quote
for future reference when you've recorded a soap go to the planner and hit the series link button to record every subsequent episode automatically.
Ned.
beware, I've got yellow skin
cossiebri
posted on 21/1/07 at 08:46 PM Reply With Quote
Sky+ was not invented to record bl*&*y soaps (even though it makes peace in our house) so i tell the missus
It was invented to record all the things you will miss while out in the garage working on your car
[Edited on 21/1/07 by cossiebri]
If it doesn't fit MODIFY it!!
Cheers BriF
liam.mccaffrey
posted on 21/1/07 at 08:57 PM Reply With Quote
i did it today by accident i started to record a program when i went out, then when i watche dit, it had recorded the lot
Build Blog
Build Photo Album
davrus
posted on 21/1/07 at 09:31 PM Reply With Quote
Sound good stuff then, so if i start to watch a program and get 15 mins in to it for eg, then decieide to record it all i do is hit the record button and it will record it from the begining then, am i correct?
ned
posted on 21/1/07 at 10:24 PM Reply With Quote
yes, should do, if you have been watching it from the start. quite handy if you get half way through and forgot to at the start or decide it's good and might want to watch it again (not the soaps!)
Ned.
davrus
posted on 21/1/07 at 10:59 PM Reply With Quote
why will it not do the soaps?
DIY Si
posted on 21/1/07 at 11:01 PM Reply With Quote
It will, just there's no conceivable reason to want to watch them again!
Sun Tzu, The Art of War
davrus
posted on 21/1/07 at 11:07 PM Reply With Quote
oh i see. when it records the time goes back by about 2-3 mins , is that normal?
[Edited on 21-1-07 by davrus]
phoenix70
posted on 22/1/07 at 12:29 AM Reply With Quote
yup perfectly normal for it to do that.
Another tip if you miss the begining of program,just rewind it and start the recording from the beginning.
