stevec
| posted on 3/2/07 at 02:07 PM |
Fiat Clankyclunko parts.
The wifes 900cc 1996 Fiat Cinquecento has done numer 2 exhaust valve,
Has anyone got a link to a online shop where I can order a set of exh. valves and a head set,?
Cheers.
Steve.
theconrodkid
| posted on 3/2/07 at 02:46 PM |
i used to use GGB engineering in bradford,the web site seems to have disappeared,try ringing them
who cares who wins
pass the pork pies
mookaloid
| posted on 3/2/07 at 04:52 PM |
http://www.shop4parts.co.uk/ ?
| posted on 3/2/07 at 05:00 PM |
Has Nat got any bits left?
He's cut one up to make a grasser.
russbost
| posted on 3/2/07 at 08:03 PM |
Scrap it - I'll have the lower column, rack & track rod ends!!!
stevec
| posted on 3/2/07 at 10:03 PM |
Mark Allanson
| posted on 3/2/07 at 10:14 PM |
Hydraulic tappets normally expire on these every 60k miles, is it worth transplanting a ohc fire engine out of a punto 55? A complete engine would
probably cost less than an exhaust valve, you would end up with more power, better economy and a bullet proof engine (replace the cambelt &
tensioner bearing before the swap)
stevec
| posted on 3/2/07 at 11:09 PM |
Very good.
mention more power to my SWMBO and she wants to know how much more it will cost in petrol.Where do they get this sort of logic.
Mark Allanson
| posted on 3/2/07 at 11:35 PM |
I like it , you could put the 1242cc DOHC from the puntoII with 85bhp, this would give you the same economy unless the mrs gets to like the extra
power, and then you would only get about 50mpg!!
