Author: Subject: OT GTI Question - What is it
pajsh
posted on 4/2/07 at 06:06 PM Reply With Quote
Can anyone tell me what the tank below the expansion tank is. Its black plastic and has three connections. One is a tube to the throttle body, one is a sensor and the other goes to what I think is the fuel pressure regulator.
I think its a carbon filter but the problem is the sensor is making a fast clicking noise that I'm sure it shouldn't.
Can someone tell me what it is and why it's clicking. Probably FUBAR I guess.
Car is a Mk4 Golf GTi 1.8 20v Turbo 1999
Ta.
[img][/img]
I used to be apathetic but now I just don't care.
robertst
posted on 4/2/07 at 06:16 PM Reply With Quote
swirl pot?
Tom
NeilP
posted on 4/2/07 at 06:37 PM Reply With Quote
If it is a carbon canister then it would be to soak up hydrocarbon fumes which would normally come from the fuel tank whilst the car is sat around doing nada - By throttle body do you mean the the plenum intake valve (i.e an injected engine)? - If so then a bit of a mystery as no fuel here.
Is what you think is the fuel pressure regulator mounted to the top of the camcover? - This might be an expansion valve in which case you would get unburnt HCs that leak with other gases back up the valve stem seals.
Regardless - If it's making a din then bound to be fecked - Sorry can't be more help...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
martyn_16v
posted on 4/2/07 at 06:48 PM Reply With Quote
The carbon canister on my old MR2 used to buzz away to itself quite happily when the engine was off, I spent ages searching for an angry wasp in the engine bay until I eventually worked it out. Just because it's making noise doesn't necessarily mean it's berked
Gav
posted on 4/2/07 at 06:50 PM Reply With Quote
This is the same on my leon cupra and it seems the ticking is normal, well if its not mines being doing it for neigh on 4 years!
