Author: Subject: Tintop Squeaky brakes
Avoneer
posted on 7/2/07 at 11:19 PM Reply With Quote
My old Xantia has developed the squeaky brake syndrome.
Had all 4 wheels off and pads still have plenty of friction.
Discs don't feel too scored either.
Don't think it's a warped one as the sound is constant, but only on gentle braking.
Doesn't happen if you stop with just the handbrake either.
Any thoughts?
Ta,
Pat...
RazMan
posted on 7/2/07 at 11:21 PM Reply With Quote
Have you tried Coppaslip on the backs of the pads?
Raz
ayoungman
posted on 7/2/07 at 11:26 PM Reply With Quote
As above, copperslip on back plates, give a good blow out of dust( wear a mask). Also, ensure discs arn't glaised. If they've been running hot, they can produce an annoying squeel.
"just like that !"
Avoneer
posted on 8/2/07 at 07:18 AM Reply With Quote
Ok, copperslip it is.
All 4 calipers look like they've done the 131k the car has done though.
Best get plently of rags and brake cleaner!
Pat...
jimgiblett
posted on 8/2/07 at 11:24 AM Reply With Quote
Or proper Bendix Blue anti squeal if the Copaslip doesnt want to play.
posted on 8/2/07 at 11:32 AM Reply With Quote
As said - Copperslip is a good and cheap thing to try first. In many cases it will work, and if it doesn't then you haven't spent much. A can of Gunson's brake part cleaner is cheap enough and will also help. Open air and a mask are essential, for the cleaner's fumes and the brake dust! Just don't get any of the grease anywhere near the working face of the pads, obviously...
RazMan
posted on 8/2/07 at 11:42 AM Reply With Quote
Is that the really stick goo that you put on the backs of pads? I can't find it anywhere - got a link?
*edit* Found something similar here
[Edited on 8-2-07 by RazMan]
Raz
jimgiblett
posted on 9/2/07 at 06:08 PM Reply With Quote
Yes squeze onto back of pad. I got mine from my local factors. Not that expensive IIRC but more than the stuff on Razman's link have yet to find anything better.
If you cant get any I'll pick up a bottle for you and post on.
Jim
[Edited on 9/2/07 by jimgiblett]
iank
posted on 9/2/07 at 06:43 PM Reply With Quote
Rally design stock 'Bendix 97A Blue-goo noise suppressor' it in the new catalogue (page 30) but it doesn't seem to be on the web shop yet. £6.80 a tube
[Edited on 9/2/07 by iank]
Anonymous
wacomuk
posted on 9/2/07 at 08:59 PM Reply With Quote
My Nissan has warning squeakers built in to the pads. its a small piece of metal that touches the disk when the pads get low
http://www.insightbookingsolutions.co.uk
