New Topic New Reply
Author: Subject: Least stressed member
Nitrogeno25
posted on 12/2/07 at 02:56 PM Reply With Quote
Are there any member of the chassis candidates for thinner wall (maybe 18 awg).
I'm thinking of the least stressed memebers or the shortest ones. What about the vertical tubes?
Thanks a lot.
3GEComponents
posted on 12/2/07 at 03:05 PM Reply With Quote
If it's any help, when caterham did the csr chassis they actually increased some tube wall thickness' in order to make it more rigid.
James
posted on 12/2/07 at 03:36 PM Reply With Quote
Thanks a lot.
Just read the Cymtrics chassis mods... they'll tell you ways to reduce weight AND increase torsional stiffness.
Confused but excited.
posted on 12/2/07 at 08:01 PM Reply With Quote
I think that I'm probably the least stressed member, but I'm way over 18 gauge in thickness.
novacaine
posted on 12/2/07 at 09:11 PM Reply With Quote
hehehe!
that was what i thought this post was going to be about when i read the link lmao
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
IainB
Builder
Posts 236
Registered 17/11/05
Location Glasgow
Member Is Offline
Photo Archive Go!
Building: Fiat X1/9 - GRP widebody, Bike carbs, Megajolt
posted on 12/2/07 at 09:15 PM Reply With Quote
I wake up with a stressed member most mornings, im sure I aint the only one....
Iain
http://s43.photobucket.com/albums/e365/IainB1986/
flak monkey
posted on 12/2/07 at 09:17 PM Reply With Quote
You can safely make the whole chassis out of 18g tube.
Increasing the wall thickness of the tubes add pretty much zero stiffness (actually it adds none, the only thing they affect is the braking/buckling strain/strength of the tube), much better off strategically adding thinner tubes in various locations to increase stiffness.
[Edited on 12/2/07 by flak monkey]
Sera
http://www.motosera.com
New Topic New Reply
