macnab
posted on 13/2/07 at 02:26 AM |
Halloween…
So there I was drinkin my tea, looking at the front of the motor and I thought to myself that looks a bit like a pumpk…
Ohhh isn’t is sooo scary!!! GRRRrrr!!
macnab
| posted on 13/2/07 at 09:17 AM |
no comments yet...you all must be in shock
trogdor
| posted on 13/2/07 at 09:29 AM |
that is quite evil looking, is amazing how faces appear in also anything. see them all the time in images of the seafloor that i am using for my
degree, convinced there was an image of homer simpson last year!
oh what are all the holes for?
[Edited on 13/2/07 by trogdor]
macnab
| posted on 13/2/07 at 10:05 AM |
homer simpson on the seabed! what you been smokin?!
Purpose of the holes? Well apart from looking ‘evil’ the front ones will let the radiator heat out of the nose cone without use off the fan in traffic
and the two other ones are for the air feed to the plenum (is that how you spell that, doesn’t look right) chamber when I fit the fuel injection,
hopefully there will be a ram effect from that.
| posted on 13/2/07 at 10:43 AM |
ooooh, look who got a jugsaw for Christmas
are ewe being serious?
the tirangular (now there is a special name that eludes me for this) shaped wit hte 2 holes - I think for the hole to be most effecive it needs to be
at the end of the "funnel" as it were.... but then these aren't F1 cars.
iank
| posted on 13/2/07 at 10:51 AM |
It's a NACA duct (think it's pronounced knacker )
I suspect the ones at the front for letting out rad heat when stationary won't do much, but they look good anyway.
[Edited on 13/2/07 by iank]
Anonymous
| posted on 13/2/07 at 11:15 AM |
yep; NACA.
quote: The shape and depth change of the duct are critical for proper operation.
here
macnab
| posted on 13/2/07 at 11:26 AM |
don't know how effective it will be but it will be cold and it will be windy and far better than from inside the engine bay. But your all
missing the point, it looks 'Evil'!! and that all that matters
trogdor
| posted on 13/2/07 at 03:01 PM |
well it certainly ticks the evil box
honestly you can sometimes see what looks like faces in the sonar images of the sea floor, and we once found one that looked like homer simpson from
the side!
is annoying as you are looking for volcanoes and faults not peoples faces!
smart51
| posted on 13/2/07 at 03:30 PM |
http://en.wikipedia.org/wiki/NACA_Duct
"This type of flush inlet generally cannot achieve the larger ram pressures and flow volumes of an external design"
"When properly implemented, it allows air to be drawn into an internal duct, often for cooling purposes, with a minimal disturbance to the
flow"
