Author: Subject: How can I stop Rain blowing under the Garage Door
John P
posted on 21/2/07 at 11:57 AM Reply With Quote
The front of my garage is always wet where rain blows under the door.
I'm sure I've seen an advert for a rubber strip which fits along the botton of the door rather like a draft excluder.
Does anyone know who sells these?
John.
jambojeef
posted on 21/2/07 at 12:07 PM Reply With Quote
My old man made a little concrete bump which sits just behind the garage door to try and keep the rain out...
Think it was an 'end of the tether' solution to be honest but it works!
Humbug
posted on 21/2/07 at 12:10 PM Reply With Quote
You could build a little lip of concrete just inside the door. Or a small (half inch x half inch?) piece of angle iron fixed to the floor? Either would stop normal rain from coming in, but wouldn't be much hassle for driving over.
Alternatively, if it's only a smlll gap under the door, how about going to a scrappy and liberating a door seal - you know, the one with the grippy U profile + a sort of rubber tube on the outside.
greggors84
posted on 21/2/07 at 12:17 PM Reply With Quote
Woolies trim might have something your looking for.
Link
Chris
The Magnificent 7!
posted on 21/2/07 at 12:24 PM Reply With Quote
I've got a Henderson sectional that has rubber trim all round and a nice thick (100mm?) 'bumber' at the bottom that seals even though the floor is a bit uneven.
You could aslo move somewhere where it doesnt rain??
RoadkillUK
posted on 21/2/07 at 12:33 PM Reply With Quote
A locost solution (depending of course on the garage door) is to nail some carpet to the back of the door at the bottom
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Hammerhead
posted on 21/2/07 at 12:35 PM Reply With Quote
screw some rubber to the back of the door
James
posted on 21/2/07 at 12:38 PM Reply With Quote
ScrewFix do one. It's about 2.5m long (can be cut down!) and you screw/rivet it to the bottom of door.
Not got round to fitting mine yet... but it looks like it'll work.
HTH,
James
Colnago_Man
posted on 21/2/07 at 12:46 PM Reply With Quote
I used a length of Damp Proof Course (split lenght ways so its about 2 inches long) bonded onto the bottom of the garage, worked perfectly and wont rot.
SeaBass
posted on 21/2/07 at 03:05 PM Reply With Quote
I bought two lengths of standard door brush strip which work brilliantly. They also keep the heat in when you fire up the garage heater.
Cheesr
andyps
posted on 21/2/07 at 03:15 PM Reply With Quote
I have heard of carpet etc. freezing and the door not being openable. I screwed a piece of wood across my floor just inside the door with a bead of silicon sealant under it. Bit of a pain when pushing a car across it, but otherwise works Ok and easier than concrete.
Nick Skidmore
posted on 21/2/07 at 03:25 PM Reply With Quote
Pirelli webbing
It's the rubber stuff that gives seats 'suspension'
It's cheap, buy it by the metre and works, I used it some years back very successfully.
miegru
posted on 21/2/07 at 03:56 PM Reply With Quote
All the above solution are for closing the gap. If that's ok; good. If you want too keep some gap for ventilation (like if you have a pre-fab box with no ventilation except round the door) I would cut a small canal just inside the garage. 1cm wide and 1.5 cm deep (v-shape should do it if you can link it to a lower point outside. 20minutes work with an axle grinder.
PeterW
posted on 21/2/07 at 04:20 PM Reply With Quote
I used this stuff here and its great
No water ingress, even with a sloping driveway
Peter
Avoneer
posted on 21/2/07 at 06:19 PM Reply With Quote
1 length of 2x1" wood has been fine on my last two garage floors (just behind the door).
Siliconed and screwed with rawl plugs to the floor and the painted.
Should cost less than £5 all in.
Good to rest the ramps against as well so they don't slip.
Pat...
zetec7
posted on 21/2/07 at 09:29 PM Reply With Quote
Of course, if you want a truly LOCOST way of fixing it...try lookng for a commercial building in your area that's being remodeled. Lots of commercial buildings have wall moldings (at the floor) made of rubber, usually 2-3" high. A chunk of that could probably be had for free...screw it onto the bottom of the garage door, and problem is gone...
http://www.freewebs.com/zetec7/
geoff shep
posted on 22/2/07 at 06:34 PM Reply With Quote
Ditto Avoneer - cheap and cheerful. It makes sweeping out slightly more inconvenient but works remarkably well.
