Author: Subject: Heater Hoses joining
TangoMan
posted on 3/3/07 at 11:32 PM Reply With Quote
I need to find a 16mm T piece for my heater/expansion tank hoses.
Car Builder Solutions only do 15mm and that is all I have found on ebay.
Any ideas as I have tried the 15mm ones and they leak.
Summer's here!!!!
graememk
posted on 3/3/07 at 11:37 PM Reply With Quote
get silocone hose, its softer and clamps up better
Dave Castle
posted on 3/3/07 at 11:43 PM Reply With Quote
Use a plumbers 15mm yorkshire fitting the pipes 15mm but the fitting is bigger and the solder ring ridge will provide something for the clip to to grip.
[Edited on 3/3/07 by Dave Castle]
omega 24 v6
posted on 3/3/07 at 11:50 PM Reply With Quote
Get a plumbers solder ring type t piece. It fits 15mm o/d pipe and as such will be at least 16mm o/d. You may need to extend it using a bit of pipe and a straight connector to get enough length for a clip.
Like this
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100123&ts=65708&id=52984
Oops I'm a slow typist
[Edited on 3/3/07 by omega 24 v6]
TangoMan
posted on 3/3/07 at 11:55 PM Reply With Quote
Thanks gents.
Looks like a trip to B&Q is on for tomorrow.
Summer's here!!!!
Russiow
posted on 4/3/07 at 11:33 AM Reply With Quote
Tweekys do a 16mm Nylon T for fuel and oil that would be ok proberly.....
