Author: Subject: Drive way
matt.c
posted on 10/3/07 at 05:55 PM Reply With Quote
Drive way
Sorry, i know this aint locost but does anyone know how much it's going to cost to brickweave my driveway?
Its about 40ft x 15ft
What about crazy paving and other types?
NO GRAVEL
any help will be very usefull
Cheers all
matt
posted on 10/3/07 at 06:02 PM Reply With Quote
I'm sure there are some travellers around that will give you a quote!!! My neighbour had his done recently by a reputable company IIRC he said it cost several thousand
Jasper
Same size as mine and I wanna use brick too - be interested to get an idea of price.....
Pdlewis
posted on 10/3/07 at 06:14 PM Reply With Quote
I have a company which does this I used the following guide prices which include digging, muck away, sand, type 1 road stone and bricks
Standard Block pavers £50 per m2
Tegualre drivesets (expensive blocks) £85 per m2
matt.c
posted on 10/3/07 at 06:31 PM Reply With Quote
Ok cheers, but im a real dumb arse when it comes to working out how many m2 in my measurements. Can anyone help?
Pezza
posted on 10/3/07 at 06:42 PM Reply With Quote
£2800 for the cheaper stuff
£4760 for the more expensive
Providing I got my calculations right :p
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
DIY Si
posted on 10/3/07 at 06:44 PM Reply With Quote
80m2 give or take a bit.
Sun Tzu, The Art of War
Pezza
posted on 10/3/07 at 06:45 PM Reply With Quote
40 x15 is 600 sq ft or 55.74182 sq m :p
matt.c
Cheers Pezza,Pdlewis and si,
[Edited on 10/3/07 by matt.c]
DIY Si
posted on 10/3/07 at 06:48 PM Reply With Quote
Damn the calculator on a PC. I'm used to a Mac. You are correct 55.74m 2 it is. God only knows what I hit wrong there.
Humbug
posted on 10/3/07 at 06:53 PM Reply With Quote
Give or take quite a bit, if my calcs are right - I make it about 55m2
Doh! too slow
[Edited on 10.03.2007 by Humbug]
Simon
posted on 10/3/07 at 07:03 PM Reply With Quote
Like "Build Your Own Sports Car for £250 - Give or take a bit"
Simon
Avoneer
posted on 10/3/07 at 09:18 PM Reply With Quote
Concrete it.
Easy to clean when you've leaked on it.
Cheaper as well.
Pat...
pif
posted on 10/3/07 at 09:45 PM Reply With Quote
my drive is 11 metres long x 2.5 metres wide at thin end and 5 metres wide at widest point and to block paved to a meduim std by small local firm including 20 metres of path down the side and around the back of the house was £3000 all in and took them 2 days.
hth
been a bit of a rush job really, bodged it all together in just 5 1/2 years.
MikeR
posted on 10/3/07 at 11:18 PM Reply With Quote
I graveled an area at the front of my house for either 400 or 500 quid (can't remember). If i ever leak oil i just move the gravel around. Stops burglers as they make a noise walking over it, drains easily and won't go wonky in a few years as the sand underneeth gets washed out.
(although the toy car does have a brick 'road' to the garage)
Chippy
posted on 10/3/07 at 11:49 PM Reply With Quote
Just had a price for doing my patio, 32' x 11', (don't do metric), £900 in brick block paviours. Mind you that doesn't include the blocks, as I had purchased those intending to DIY it, but SWMBO said get it done profesionaly, (wonder if thats because I brought the blocks two years ago). Ray
posted on 10/3/07 at 11:51 PM Reply With Quote
you can get concrete pressed into the shape of bricks, so it looks good but cannot settle. The only give away is the expansion joints.
My pal had a vast area (about 100m squared) done for £800 labour only, supplied his own materials. Included concreted edges in a fancy shape. Anyone in Yorkshire who wants it doing i can put through to the guy, an old pal who retired from kitchens into landscaping.
