Steve&Steve
| posted on 17/3/07 at 05:55 PM |
Plumber / Water Board....HELP Needed.
We had to turn off the water to the house today to fix a small dripping joint on the inlet pipe. Main stopcock in road was very tight but we managed
to turn it till water pressure was low (just a low trickly), but not quite stopped.
Then the handle sheared off!
What can I do about this?, I only want to turn it back on this once as there are internal valves i can use for normal plumbing changes etc. I have
tryed Mole grips and although I got quite good purchase it wasnt enough to free it up that first twist.
Please HELLLLLLLLLLLLP,
Cheers, Steve
trikerneil
| posted on 17/3/07 at 06:01 PM |
Have you got a cam type stud extractor you could put over the spindle?
ACE Cafe - Just say No.
| posted on 17/3/07 at 06:06 PM |
I couldn't turn ours off a couple of years ago when I was doing an outside tap which came off the main before the house stop cock so I phoned
the water board. They came out within two days, dug the pavement up and fitted a new one. I didn't get a bill so I assume it was their
responsibility.
ruskino80
| posted on 17/3/07 at 06:12 PM |
if you can loosen the gland nut first this should ease the turning of the spindle,but beware not to remove it altogether
ps cracking photgraphy!!
[Edited on 17/3/07 by ruskino80]
Wadders
| posted on 17/3/07 at 06:27 PM |
second what pete said, phone em up, they should come out within an agreed time frame, and it wont cost you anything.
Al.
responsibility.
graememk
| posted on 17/3/07 at 06:42 PM |
i did that at my parents house they turned up within a few hours dug up the front garden and my parents never said anything about a bill
Danozeman
| posted on 17/3/07 at 06:46 PM |
Its there responsibility get them out to do it!
Dan
| posted on 17/3/07 at 07:19 PM |
and make out its an emergancy, tell them there are kids in the house and no water, should see them out in a few hours. Its free because they are
responsible for the supply and the outside stopcock.
[Edited on 17/3/07 by JoelP]
