Author: Subject: FWD hubs on the back????
rayward
posted on 21/3/07 at 02:33 PM Reply With Quote
does anyone see a problem with you using FWD hubs on the rear (in a FWD to RWD conversion, and just fixing the hubs (to stop them steering) with a link bar??.
Ray
[Edited on 21/3/07 by rayward]
Mr Whippy
posted on 21/3/07 at 02:41 PM Reply With Quote
I'm sure this has been use before on other kit cars.
Mr Whippy
posted on 21/3/07 at 02:55 PM Reply With Quote
Could you not arrange it so that when the car rolls on a corner the bump steer would also steer, like those cars with 4x4 steering?
Howlor
posted on 21/3/07 at 02:58 PM Reply With Quote
Just make sure Ray you get the lump the right way round otherwise you'll end up with 5 back and only 1 forward gear!
3GEComponents
posted on 21/3/07 at 03:30 PM Reply With Quote
posted on 21/3/07 at 03:46 PM Reply With Quote
The rear engined kits out of Sylva use front dirive hubs on the back.
The steering arm gives you some opportunity for adjustment
3GEComponents
posted on 21/3/07 at 04:07 PM Reply With Quote
And by mounting the chassis end off centre, either higher or lower, would also steer the back wheel as the car rolls!
ch1ll1
posted on 21/3/07 at 05:04 PM Reply With Quote
how did you get a picture of my car?
andyps
posted on 21/3/07 at 05:05 PM Reply With Quote
The MG F/TF used Metro front hubs all round.
zetec7
posted on 21/3/07 at 06:17 PM Reply With Quote
If it helps to ease your mind, the Pontiac Fiero was built exactly this way (FWD package, complete, transposed to the rear), and it works very well!!
http://www.freewebs.com/zetec7/
bob
posted on 21/3/07 at 07:23 PM Reply With Quote
Sylva mojo link
http://www.sylva.co.uk/mojobrochure.htm
The info here is good, also the linked pics
lsdweb
posted on 21/3/07 at 09:37 PM Reply With Quote
A cable operated handbrake might be your only problem although easily fixed. Ditto to the adjustable comments.
Wyn
turbodisplay
posted on 21/3/07 at 10:05 PM Reply With Quote
I`ve used hubs at rear, vauxhall vectra (quite good design).
Re tie rods:
Short will result in the wheels toeing in in up/down movement.
Very long will toe out, but to a much lesser extent.
For little to none toe the joints need to be inline with the suspenstion mouting points, and need to ideally be parrallel to the lower arm.
On mine I have very little toe, hardly noticable over +- 3 inches travel.
Darren
iank
posted on 21/3/07 at 10:26 PM Reply With Quote
As the previous post, you remove bump steer from the back the same way as you would from the front. Think of the locking arms as the arms from a steering locked in the straight ahead position.
Anonymous
