Author: Subject: indy vs vortx vs book
jlparsons
posted on 24/3/07 at 01:07 PM Reply With Quote
Right - i'm off the mark! Getting started in the first job of my build... widening my garage.
WHile I do, i'm contemplating the foundation of my build and I've narrowed down my options. I want a lightweight bec LSIS car, zx12r engine, plastic seats and wind deflector, and SWMBO agrees. However, which chassis to go for...? I do want to weld up my own and am very temped by the book (gibbs) chassis. On the other hand the mnr vortx and mk indy look very good vlaue for basic kits to leapfrog a lot of (albeit enjoyable) work and get on the road faster.
So to help me decide, i have two questions:
What are the pros and cons of the indy and vortx designs?
and
how will a well built new-book chassis perform in comparison to a bought kit chassis?
thanks folks
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
StevieB
posted on 24/3/07 at 02:58 PM Reply With Quote
I have an Indy (or, half an Indy so far), and have found it to be just right for me - I have a very small garage and simply wouldn't have been able to comfortably weld up my own chassis.
I've never looked properly at the MNR, so wouldn't be able to comemnt on it, but I would add one thing:
If you go for a manufactured chassis, don't get it powder coated from the supplier - MK's powder coating option is a bargain and good quality, but there's loads of little bits I would have liked to have changed (brakets, moutning plates etc.) and would have welded them up, but have just ended up with loads of bits of ali riveted in instead.
jlparsons
posted on 24/3/07 at 03:59 PM Reply With Quote
That's valuable, thanks mate.
