jimgiblett
| posted on 1/4/07 at 10:07 AM |
Recommend a fabricator
My son's baseball club desperately needs one of these.
  Portable Baseball Backstop
They are available in the US but not in the UK and shipping is extortionate.
Can anyone help they have a budget of approx £1,000.
U2U or email me on jimgiblett@hotmail.com
Jim
[Edited on 1/4/07 by jimgiblett]
iank
| posted on 1/4/07 at 10:12 AM |
Anonymous
jimgiblett
| posted on 1/4/07 at 10:15 AM |
Thanks iank. I couldn't remember how to load the pic.
froggy
| posted on 1/4/07 at 01:09 PM |
how about using some building site security fencing,it comes in 12' long by 6' high and joins together with bolt to gether clamps so the
only fab rication would be for the triangle shaped side pieces to stiffen it up. you can get new sections for around £40 a panel
jimgiblett
| posted on 1/4/07 at 08:26 PM |
That sounds like an excellent idea. But I have been searching for a supplier and they all seem to be with bars rather than chain link. Do you know
contact?
Jim
oadamo
| posted on 1/4/07 at 08:31 PM |
Jim
if you have a drawing so somthing i could quote you the job but i dont no how much it will be what finish are you after
adam
jimgiblett
| posted on 1/4/07 at 08:46 PM |
adam
Its basically as per the picture. Each square is 5" so in the picture you can see 7 rectangles (consisting of two squares) and two triangles.
The angles of the wings are 30 degrees or 150 degrees on the inside. The cage will be outside a lot so galvanised would be best but may consider
other corrosion resisting coating.
Jim
oadamo
| posted on 1/4/07 at 08:58 PM |
do you want the trolley thing with it to move it about or just a stand alone unit.
jimgiblett
| posted on 1/4/07 at 09:33 PM |
The trolley will be needed but depends on how much it is going to all add up to. Might just use a modified sack truck.
- Jim
oadamo
| posted on 1/4/07 at 09:46 PM |
ill get back to you tomorrow with a quote prob about 5 o clock after i finish work
adam
jimgiblett
| posted on 1/4/07 at 11:03 PM |
Excellent
