<<  1    2  >>
New Topic New Reply
Author: Subject: Pre SVA Pic's Comments Please!!!
mike smith1
posted on 1/4/07 at 05:47 PM Reply With Quote
Just a few pics of car, just wanted to see if you guys could spot anything major and silly little things we have missed!
Mike
mike smith1
posted on 1/4/07 at 05:48 PM Reply With Quote
Front Near Side
mike smith1
Passenger Footwell
mike smith1
posted on 1/4/07 at 05:49 PM Reply With Quote
Rear
mike smith1
posted on 1/4/07 at 05:50 PM Reply With Quote
Is this vertical enough??
mike smith1
I need to make this SVA Friendly any ideas??
posted on 1/4/07 at 05:51 PM Reply With Quote
Front braided hoses need covering and suspect that top ball joint nut needs a cover.. Battery cut off could be a problem??
[Edited on 1/4/07 by rusty nuts]
mike smith1
posted on 1/4/07 at 05:52 PM Reply With Quote
Steering Column and Master Cylinder
mike smith1
Tunnel
mike smith1
Under Dash view
fideel109
posted on 1/4/07 at 05:53 PM Reply With Quote
I did my SVA last week, and I did cover up the lock nut of the top ball joint (sharp edges).
tegwin
posted on 1/4/07 at 05:54 PM Reply With Quote
Cant help you, but damn that looks the dogs danglies!!!
mike smith1
Top ball joints will be covered after wheel alignment. Braided hoses with a spiral wrap??
Will think of something to cover battery cut off.
Thanks matey got me some more jobs to do already!! Super fast posting!
Mike
fideel109
posted on 1/4/07 at 05:55 PM Reply With Quote
Are they any reflectors on the back?
mike smith1
posted on 1/4/07 at 05:56 PM Reply With Quote
Nope but they are on the shopping list!
Cheers Mike
zetec
posted on 1/4/07 at 05:57 PM Reply With Quote
Very nice car. Beware re headlamp bar ends, and is that brake pipe from the master cylinder supported enough?Also are the front indicators out far enough. Hope you fly through! Good luck.
[Edited on 1/4/07 by zetec]
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
rayward
posted on 1/4/07 at 06:00 PM Reply With Quote
as said, ball joint locknuts,
possibly unsecured length of copper brake pipe to master cylinder.
re the cutoff switch, seen a pic somewhere on hear of the key "encased" in a clear resin, kind of like a big marble
hth
Ray
mike smith1
posted on 1/4/07 at 06:03 PM Reply With Quote
Front indicators what is the dimension required as i cant get to my draft manual at min!!
Mike
stevec
posted on 1/4/07 at 06:04 PM Reply With Quote
Fog light, Is it off vertical or is it the picture?
You may need to cover top and bottom of the shocks.
Looks really nice though.
Steve.
[Edited on 1/4/07 by stevec]
snoopy
posted on 1/4/07 at 06:06 PM Reply With Quote
both shocker spring adjusting nuts the BIG ones the cutoff switch and maybe its just the pic but it appears the aluminium the cutoff switch mounts to protrudes past the lower box section if it does its a fail
stevec
posted on 1/4/07 at 06:10 PM Reply With Quote
Quote,
See link for indicator positions.
Steve.
http://westfield-world.com/svalights_front.html
jacko
posted on 1/4/07 at 06:11 PM Reply With Quote
nut on the mirror at the bottom
mike smith1
Thanks Snoopy, would you like to come up and have a proper look!!
Mike
bob
posted on 1/4/07 at 06:14 PM Reply With Quote
I found a large gator chopped up covered the shock adjustment area, and covered the rest as this. Rescued attachment MK Indy build pics 168.jpg
chockymonster
posted on 1/4/07 at 06:26 PM Reply With Quote
Fog light looks off vertical as previously mentioned.
Easy fix is to put some small 4mm black vacuum tubing between the top of the foglight and the surround to pad the top out.
It worked fine for me at SVA and southampton have a rep for being fussy.
<<  1    2  >>
New Topic New Reply
