Author: Subject: Bullet cam
cossiebri
posted on 9/4/07 at 07:24 PM Reply With Quote
Bullet cam
Just noticed this...
http://www.halfords.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&mpe_id=12054&jspStoreDir=HalfordsConsumerDirect&intv_id=375 20&partNumber=543025&evtype=CpgnClick&langId=-1&catalogId=10151&ddkey=ClickInfo
Anyone using them?
seems pretty good value
[Edited on 9/4/07 by cossiebri]
If it doesn't fit MODIFY it!!
Cheers BriF
cossiebri
posted on 9/4/07 at 07:28 PM Reply With Quote
Can't get link to work
try this
http://www.halfords.com/wcsstore/HalfordsConsumerDirect/images/catalog/80-543025a.jpg
Cheers BriF
Guinness
posted on 9/4/07 at 07:34 PM Reply With Quote
On my shopping list, but from here http://www.firebox.com/product/1732?src_t=cat&src_id=gadgets
Discussed in depth on Blatchat here http://www.blatchat.com/T.asp?id=121145
Mike
posted on 9/4/07 at 08:23 PM Reply With Quote
built in memory is very slick. 32mb aint long though, maybe 20 mins? At a guess compared to mine which records to tape. Worth someone trying it.
Jubal
posted on 9/4/07 at 09:00 PM Reply With Quote
I have one of these. Built a mount for it this weekend and so far I haven't managed to get a single film despite lots of test runs. It appears to shake the SD card loose when hard mounted so will be going back for an exchange. The results I have seen from other people have been good enough considering the price:
Linky
The internal memory is good for 43 seconds at 640x480. i.e. useless. You need 1Gb per half hour of filming at that res.
Tim 45
posted on 9/4/07 at 09:03 PM Reply With Quote
At 640 x 480 @ 30fps 1GB should be good enough for about an hour and a half
JUD
posted on 9/4/07 at 09:28 PM Reply With Quote
I have one of these. Quality is OK, and you can get 2Gb SD cards from www.7dayshop.co.uk for about £15. 2Gb is the max it can address, so no point getting anything bigger.
Only problem I have is that the mic is in-built which means it is exposed to vehicle velocity windspeeds. This means any high speed footage is accompanied by a hurricane sound track.
Planning on using mine for trackdays this year - see how I get on. May upgrade if the recording bug bites.
In summary not a bad entry, but not the same as a good bullet/remote camera set up.
Martin
MK Indy Blade
Daimo_45
posted on 10/4/07 at 03:19 AM Reply With Quote
Seen that Oregon Scientific bullet cam in the link above on TV (testing it on the gadget show) was amazing for the price!
Furious D
posted on 10/4/07 at 08:13 AM Reply With Quote
A friend of mine had one on his motorbike. He attached it to the front forks, great veiwing after a track day. I remember that there was a lot of wind noise.
D
posted on 10/4/07 at 07:27 PM Reply With Quote
microphones need a lot of muffling. With mine i stuff it into the bag beside the camcorder and it still picks up everything you want to hear.
