Author: Subject: Spliting an AVI file
gjn200
posted on 27/7/03 at 04:09 PM Reply With Quote
I've got a 850mb avi file and want to split it so I can burn it on 2 cd's, now how do I do it??
<- Me!
ijohnston99
posted on 27/7/03 at 07:12 PM Reply With Quote
Try....
http://www.boilsoft.com/videosplitter/download.html
or http://www.divx-digest.com/articles/cutavi.html
Ian
gjn200
posted on 27/7/03 at 08:25 PM Reply With Quote
Neither work, they wont read the xvid codec
<- Me!
Noodle
posted on 28/7/03 at 06:18 AM Reply With Quote
Make sure you've got the XViD codec installed
Then try using VurtualDub. I've done a little test on my machine and it split successfully.
Neil.
[Edited on 28/7/03 by Noodle]
gjn200
posted on 28/7/03 at 07:45 AM Reply With Quote
Arse.
Are there different types of xvid codec? I downloaded one to watch it and it works fine, but the splitters say its not there????????????
<- Me!
posted on 28/7/03 at 09:20 AM Reply With Quote
xvid cedoc
yhw si ydobyreve gnitirw sdrawkcab.?VirtualDub works on mine with the 5.02 on it.
yours, Pete.
P.S. It's backwards.
ned
posted on 28/7/03 at 09:47 AM Reply With Quote
Pete,
jgoevd version 5.02 fjkspigrg about fdsjklg v5.025 gfoigrd poijkldfy dfsa codec viddix v2?
oh and £2.50 for the other.
Ned.
beware, I've got yellow skin
timf
posted on 28/7/03 at 10:03 AM Reply With Quote
ned your making less sense then usual today, been sniffing exhaust fumes again
Tim
ned
posted on 28/7/03 at 10:21 AM Reply With Quote
yeah, ran up the beast of a sierra before i stripped it at the weekend. either that or i didn't see pete say it was backwards and thought he was talking jibberish, so i joined in!
Ned.
Noodle
posted on 29/7/03 at 06:03 AM Reply With Quote
XVid is a GPL'd (Gnu Public License) codec based on the modified source code for DivX. So it's not DivX as such
My tests were done using XVid 2.1 that I got from www.XVid.org of all places.
GJN, when you say the splitters say it's not there, are you talking about graphedit in DirectX8/9? If you are, then I've just tested it here and it worked OK.
Again, check the codec for the latest version and try again.
Neil.
gjn200
posted on 29/7/03 at 03:36 PM Reply With Quote
Found a later version of the codec, and it works. But I can't get the lip sinc right
<- Me!
Noodle
posted on 29/7/03 at 04:30 PM Reply With Quote
If you want to re-sync the audio and it's just offset a bit, when splitting in VirtualDub, goto Audio menu, pick Interleaving, and change the value in Audio Skew Correction.
If the synch gets worse as the file progresses, then the audio's been encoded at a different frame rate to the video (perhaps NTSC audio and PAL video for example). It's possible to de-mux (split) the audio and video sound tracks and re-encode them at different rates useing a tool such as BeSweet and re-mu then again, but ask yourself: "Is the video really worth it?" Life's too short and we've all got cars to build!
Neil.
