Author: Subject: Pug 307 Outside Temp Sensor
cerbera
posted on 18/4/07 at 05:30 PM Reply With Quote
Does anyone know where the outside temp sensor is located on a 307? The trusty Haynes manual doesnt tell (or I cant find it).
Wouldn't bother fixing something like this usually, but I think its connected to the climate control.
Ta!
b184
posted on 18/4/07 at 05:53 PM Reply With Quote
Peugeot usually put outside temp senders in the passenger door mirroe cover, if it is there then you should see or feel a small lump on lower edge.
whats wrong with the climate control?
theconrodkid
its normally behind the front bumper or in a wing mirror,should look like a small silver can about 13mm dia
who cares who wins
pass the pork pies
cerbera
posted on 18/4/07 at 05:56 PM Reply With Quote
When the outside temp reads minus whatever, even on a warm day, the a/c wont blow cold air. But when it returns to the correct temp the a/c works fine.
There is a small 'bump' on the passenger mirror, looks like its there then Thanks
[Edited on 18/4/07 by cerbera]
