cadebytiger
| posted on 29/4/07 at 04:36 PM |
what are thinners made from?
I am cleaning my webbercarbs and the book says to use petrol and thinners.
I don't have any thinnner but i do have access to a lab. was wondering if anyone knew what thinners are made from?
Rupert
novacaine
| posted on 29/4/07 at 04:40 PM |
i would assume that thinners are just alcohol/acitone/methanol based product but i might be wrong, i just assumed a thinner was just a solvent ...
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
cadebytiger
| posted on 29/4/07 at 04:43 PM |
i think you are right.
I used propan-2-ol for getting oil of the sump. worked treat! Maybe something like that would be best.
[Edited on 29/4/07 by cadebytiger]
blakep82
| posted on 29/4/07 at 04:47 PM |
technically water is a solvent.
I guess something like white spirit, but don't trust me on that, i wouldn't like to be responsible for damaging your webber carbs
________________________
geoff shep
| posted on 29/4/07 at 05:09 PM |
Thinners is a specific thing - cellulose thinners which amongst other uses is used for thinning cellulose paint and glass fibre resin - rather than
just any old thinner. Its also good for glue and sticky stuff removal but it will dissolve the paint on your car so be careful. I thought acetone
was the thing to clean carbs with - it certainly dissolves that brown dried petrol residue you get on carbs - (its nail varnish remover). Data sheet
for thinners here http://www.birdbrand.co.uk/msds/Cellulose%20Thinners.pdf
| posted on 29/4/07 at 06:06 PM |
Carb cleaner does the job better than anything else I have used
cadebytiger
| posted on 29/4/07 at 06:10 PM |
got some of that. did not know if i was going to need alot more or not?
oadamo
| posted on 29/4/07 at 06:12 PM |
i just use wd40 lol
| posted on 29/4/07 at 06:38 PM |
Various thing for example Styrene monomer, toluene
Just buy "Gun wash"
