jobsagooden
| posted on 12/5/07 at 02:16 PM |
Gear Box Oil Leak???
Helping a mate fix up a H reg golf 1.6 and we've got an oil leak from the clutch housing cover plate. Can't decide whether this is due to
a bad seal (the cover plate doesn't look like it was designed to ever seal oil in) or whether oil shouldn't be getting there in the first
place. It's definitely gear box oil leaking out.
Any body got any ideas?
NeilP
| posted on 12/5/07 at 03:10 PM |
Sounds like the input shaft seal
Depends if you can get at it from the clutch side - otherwise it's a strip through the box...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
jobsagooden
| posted on 12/5/07 at 03:13 PM |
Was dreading that response!
jobsagooden
| posted on 12/5/07 at 03:58 PM |
Does that mean oil shouldn't be anywhere near the clutch housing cover plate then?
