NS Dev
posted on 13/5/07 at 04:26 PM |
Dammit! Belt linisher packed in.....motor probs ideas???
Just a quickie, my belt linisher has just packed in which is not handy with the rate I am needing to sharpen tig tungstens!!!
I may just get a new one, but just as a quick check.........
It packed in by suddenly slowing right down as i was using it, and now it won't start, but the motor is obviously doing something, humming and
getting warm if I quickly flick it on.
there is nothign stopping it turning.
If I spin it up by hand then flick it on it runs but very slowly and making a strained sound at the motor.
if I try to start it from stopped it tries to go forwards sometimes and backwards others...........
Just wondered if that was a sign that the motor capacitor was knackered?
I checked it and it is not shorted, doesn't smell funny and wasn't hot, but could it still be that, of is the motor jaffered?
rayward
| posted on 13/5/07 at 04:33 PM |
the capcitor is probably faulty.
if you can;t get one give me a shout,, i may be able to help
hth
Ray
[Edited on 13/5/07 by rayward]
NS Dev
| posted on 13/5/07 at 04:44 PM |
found some on ebay, I assume its a run capacitor as its wired in at the switch, not part of the motor.
I thought capacitors usually failed obviously (burnt or gone bang etc) but if you think it might be then i'll get one, cheaper than a sander at
any rate!
